Ir para o conteúdo principal
Roccat Vulcan II Mini Air Keycap Replacement
O que você precisa
  1. Roccat Vulcan II Mini Air Keycap Replacement, Keycap: passo 1, imagem 1 %32 Roccat Vulcan II Mini Air Keycap Replacement, Keycap: passo 1, imagem 2 %32
    • Use a keycap puller or your fingers to gently pull off the keycap.
    • Avoid using excessive force to avoid damaging the switch.
    • Lift the keycap evenly and straight up from the keyboard.
    • If you are not using a keycap puller you may need to wiggle the cap slightly to loosen it.
    • Clean the keyboard using an air blower and a soft brush to remove any debris or dust between the switches.
    • Align the new keycap with the switch stem, ensuring the small cross-shaped hole at the bottom of the keycap matches the stem. Once aligned, gently press down on the keycap until it snaps securely into place.
    • You'll hear a soft "click" sound or feel resistance when it’s properly seated.
    • Be careful with larger keys (like the spacebar or enter key) as they might have additional stabilizer clips.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Elizabeth
Membro desde: 10/24/24
226 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 3-3, Santin Fall 2024 Membro de UMass Dartmouth, Team 3-3, Santin Fall 2024
UMASSD-SANTIN-F24S3G3
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 37
Ao todo: 609
