Ir para o conteúdo principal
Roborock S5 Omnidirectional Wheel Assembly Replacement
O que você precisa
    1. Roborock S5 Omnidirectional Wheel Assembly Replacement, Omnidirectional Wheel Assembly: passo 1, imagem 1 %32 Roborock S5 Omnidirectional Wheel Assembly Replacement, Omnidirectional Wheel Assembly: passo 1, imagem 2 %32 Roborock S5 Omnidirectional Wheel Assembly Replacement, Omnidirectional Wheel Assembly: passo 1, imagem 3 %32
      • Power down your Roborock S5 vacuum.
      • Place it upside down with the omnidirectional wheel facing you.
      • Grab the wheel with your thumb and index finger and pull up.
      • The wheel assembly should pop out fairly easily and without too much force.
      • Remove any debris before replacing the wheel.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 56
Últimos 30 dias: 263
Ao todo: 3,376
