Introdução
This guide will help you remove the power cord and requires the use of a soldering iron. Check out this soldering guide for help if you don't know how to solder.
O que você precisa
Twist the plastic lid counterclockwise to unlock it.
Lift the lid to remove it from the container.
Using a soldering kit, remove the solder for the black power cord from the circuit board.
Follow this soldering guide if you need extra help!
Quase terminado!
Conclusão
