Ir para o conteúdo principal
Rival Mini Chopper MC-67BL Power Cord Replacement
O que você precisa
  1. Rival Mini Chopper MC-67BL Power Cord Replacement, Turning Gears: passo 1, imagem 1 %32 Rival Mini Chopper MC-67BL Power Cord Replacement, Turning Gears: passo 1, imagem 2 %32
    • Twist the plastic lid counterclockwise to unlock it.
    • Lift the lid to remove it from the container.
  2. Rival Mini Chopper MC-67BL Power Cord Replacement: passo 2, imagem 1 %32
    • Carefully remove the blade from the container.
    • For reassembly, the teeth on the metal shaft line up with slots on the inside of the plastic hole.
  3. Rival Mini Chopper MC-67BL Power Cord Replacement: passo 3, imagem 1 %32
    • With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
  4. Rival Mini Chopper MC-67BL Power Cord Replacement: passo 4, imagem 1 %32
    • Use your fingers to pry out the two rubber feet from the bottom cover of the base.
    • The two feet furthest from the button tower contain screws. The other two feet do not.
  5. Rival Mini Chopper MC-67BL Power Cord Replacement: passo 5, imagem 1 %32 Rival Mini Chopper MC-67BL Power Cord Replacement: passo 5, imagem 2 %32
    • Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
    • Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
  6. Rival Mini Chopper MC-67BL Power Cord Replacement: passo 6, imagem 1 %32
    • Firmly lift the bottom cover off of the base.
  7. Rival Mini Chopper MC-67BL Power Cord Replacement: passo 7, imagem 1 %32
    • Remove the smaller white gear by lifting it up with your hand.
  8. Rival Mini Chopper MC-67BL Power Cord Replacement: passo 8, imagem 1 %32 Rival Mini Chopper MC-67BL Power Cord Replacement: passo 8, imagem 2 %32 Rival Mini Chopper MC-67BL Power Cord Replacement: passo 8, imagem 3 %32
    • Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
    • Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin.
    • Continue turning the gear until completely removed from the blade-shaft.
  9. Rival Mini Chopper MC-67BL Power Cord Replacement, Power Cord: passo 9, imagem 1 %32
    • Use your hand to firmly pull the blade-shaft from the base.
  10. Rival Mini Chopper MC-67BL Power Cord Replacement: passo 10, imagem 1 %32
    • Using Phillips #2 screwdriver, unscrew two 12.7-mm screws in the middle of the base.
  11. Rival Mini Chopper MC-67BL Power Cord Replacement: passo 11, imagem 1 %32
    • Unwind power cord from the base pegs.
  12. Rival Mini Chopper MC-67BL Power Cord Replacement: passo 12, imagem 1 %32 Rival Mini Chopper MC-67BL Power Cord Replacement: passo 12, imagem 2 %32
    • Use the plastic opening tool to pry open the base from the main body.
    • These two plastic prongs are pressed fit into the base. It may take some effort to pry the base completely off.
    • Once freed, lift the base panel from the main body. The motor and power cable are connected to this panel.
  13. Rival Mini Chopper MC-67BL Power Cord Replacement: passo 13, imagem 1 %32
    • Pull the power cord wires up from underneath the wire hook on the side of the motor.
  14. Rival Mini Chopper MC-67BL Power Cord Replacement: passo 14, imagem 1 %32 Rival Mini Chopper MC-67BL Power Cord Replacement: passo 14, imagem 2 %32
    • Carefully cut into black wire casing for both wires using a small knife and peel away the black casing.
    • Only cut deep enough to remove the casing.
    • For reassembly you will need black electrical tape to keep the wires from being exposed.
  15. Rival Mini Chopper MC-67BL Power Cord Replacement: passo 15, imagem 1 %32
    • Using a soldering kit, remove the solder for the black power cord from the circuit board.
    • Follow this soldering guide if you need extra help!
  16. Rival Mini Chopper MC-67BL Power Cord Replacement: passo 16, imagem 1 %32
    • Use a small knife to cut the copper wires from the bracket holding the black wire and power cord together.
    • For reassembly the copper wires will need to be soldered together.
Conclusão
Roxanne
Membro desde: 10/17/13
522 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 4-29, Amido Fall 2013 Membro de Cal Poly, Team 4-29, Amido Fall 2013
CPSU-AMIDO-F13S4G29
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 380
