Ir para o conteúdo principal
Rival CM4015 Water Tubes Replacement
O que você precisa
    1. Rival CM4015 Water Tubes Replacement, Base Plate: passo 1, imagem 1 %32 Rival CM4015 Water Tubes Replacement, Base Plate: passo 1, imagem 2 %32
      • Remove the three 16 mm tri-point screws from the base plate.
      Pergunte ao FixBot
      Comentar
    2. Rival CM4015 Water Tubes Replacement: passo 2, imagem 1 %32 Rival CM4015 Water Tubes Replacement: passo 2, imagem 2 %32
      • Remove the base plate by pressing the plastic body away from the metal plate with your thumbs.
      Pergunte ao FixBot
      Comentar
    1. Rival CM4015 Water Tubes Replacement, Power Button: passo 3, imagem 1 %32
      • Remove the 8mm Phillips screw that attaches the power button to the inside of the coffee maker.
      Pergunte ao FixBot
      Comentar
    2. Rival CM4015 Water Tubes Replacement: passo 4, imagem 1 %32 Rival CM4015 Water Tubes Replacement: passo 4, imagem 2 %32
      • Use a flat head screwdriver to pry the power button from its slot in the body of the device.
      • Make sure the tool is pressed securely under the plastic clip, in order to not break it.
      Pergunte ao FixBot
      Comentar
    3. Rival CM4015 Water Tubes Replacement: passo 5, imagem 1 %32 Rival CM4015 Water Tubes Replacement: passo 5, imagem 2 %32
      • Clean both the button and its slot before replacing the power button.
      Pergunte ao FixBot
      Comentar
    1. Rival CM4015 Water Tubes Replacement, Heating Element: passo 6, imagem 1 %32
      • Remove the two 8 mm Phillips screws from the plastic body.
      Pergunte ao FixBot
      Comentar
    2. Rival CM4015 Water Tubes Replacement: passo 7, imagem 1 %32 Rival CM4015 Water Tubes Replacement: passo 7, imagem 2 %32
      • Remove the two 8 mm Phillips screws from the chassis of coffee maker.
      • Pull back the metal backing from the plastic body.
      Pergunte ao FixBot
      Comentar
    3. Rival CM4015 Water Tubes Replacement: passo 8, imagem 1 %32 Rival CM4015 Water Tubes Replacement: passo 8, imagem 2 %32 Rival CM4015 Water Tubes Replacement: passo 8, imagem 3 %32
      • Remove the four 8 mm Phillips screws from the inner plastic body.
      • You will need a long, thin Phillips screw driver to get this deep into the device.
      Pergunte ao FixBot
      Comentar
    4. Rival CM4015 Water Tubes Replacement: passo 9, imagem 1 %32 Rival CM4015 Water Tubes Replacement: passo 9, imagem 2 %32
      • Flip the device upside down and remove the outer plastic body from the device by pulling straight up.
      • Take your time to make sure the thin cables within the device don't tear.
      Pergunte ao FixBot
      Comentar
    5. Rival CM4015 Water Tubes Replacement: passo 10, imagem 1 %32
      • Remove the two 8 mm Phillips screws from the metal backing.
      Pergunte ao FixBot
      Comentar
    6. Rival CM4015 Water Tubes Replacement: passo 11, imagem 1 %32
      • Remove the 4 springs holding the water tubes by squeezing the 2 prongs together.
      • You may also use pliers for this step if the springs are too strong.
      Pergunte ao FixBot
      Comentar
    7. Rival CM4015 Water Tubes Replacement: passo 12, imagem 1 %32
      • Bend the heating element back and forth to wiggle the water tubes loose from the plastic.
      Pergunte ao FixBot
      Comentar
    1. Rival CM4015 Water Tubes Replacement, Water Tubes: passo 13, imagem 1 %32
      • Remove the two rubber water tubes from the heating element by firmly pulling each at a 90 degree angle from the socket.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 10-6, Livingston Fall 2016 Membro de Cal Poly, Team 10-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G6
5 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 502
