Ir para o conteúdo principal
Rival CM4015 Heating Element Replacement
O que você precisa
  1. Rival CM4015 Heating Element Replacement, Base Plate: passo 1, imagem 1 %32 Rival CM4015 Heating Element Replacement, Base Plate: passo 1, imagem 2 %32
    • Remove the three 16 mm tri-point screws from the base plate.
    Pergunte ao FixBot
    Comentar
  2. Rival CM4015 Heating Element Replacement: passo 2, imagem 1 %32 Rival CM4015 Heating Element Replacement: passo 2, imagem 2 %32
    • Remove the base plate by pressing the plastic body away from the metal plate with your thumbs.
    Pergunte ao FixBot
    Comentar
  3. Rival CM4015 Heating Element Replacement, Power Button: passo 3, imagem 1 %32
    • Remove the 8mm Phillips screw that attaches the power button to the inside of the coffee maker.
    Pergunte ao FixBot
    Comentar
  4. Rival CM4015 Heating Element Replacement: passo 4, imagem 1 %32 Rival CM4015 Heating Element Replacement: passo 4, imagem 2 %32
    • Use a flat head screwdriver to pry the power button from its slot in the body of the device.
    • Make sure the tool is pressed securely under the plastic clip, in order to not break it.
    Pergunte ao FixBot
    Comentar
  5. Rival CM4015 Heating Element Replacement: passo 5, imagem 1 %32 Rival CM4015 Heating Element Replacement: passo 5, imagem 2 %32
    • Clean both the button and its slot before replacing the power button.
    Pergunte ao FixBot
    Comentar
  6. Rival CM4015 Heating Element Replacement, Heating Element: passo 6, imagem 1 %32
    • Remove the two 8 mm Phillips screws from the plastic body.
    Pergunte ao FixBot
    Comentar
  7. Rival CM4015 Heating Element Replacement: passo 7, imagem 1 %32 Rival CM4015 Heating Element Replacement: passo 7, imagem 2 %32
    • Remove the two 8 mm Phillips screws from the chassis of coffee maker.
    • Pull back the metal backing from the plastic body.
    Pergunte ao FixBot
    Comentar
  8. Rival CM4015 Heating Element Replacement: passo 8, imagem 1 %32 Rival CM4015 Heating Element Replacement: passo 8, imagem 2 %32 Rival CM4015 Heating Element Replacement: passo 8, imagem 3 %32
    • Remove the four 8 mm Phillips screws from the inner plastic body.
    • You will need a long, thin Phillips screw driver to get this deep into the device.
    Pergunte ao FixBot
    Comentar
  9. Rival CM4015 Heating Element Replacement: passo 9, imagem 1 %32 Rival CM4015 Heating Element Replacement: passo 9, imagem 2 %32
    • Flip the device upside down and remove the outer plastic body from the device by pulling straight up.
    • Take your time to make sure the thin cables within the device don't tear.
    Pergunte ao FixBot
    Comentar
  10. Rival CM4015 Heating Element Replacement: passo 10, imagem 1 %32
    • Remove the two 8 mm Phillips screws from the metal backing.
    Pergunte ao FixBot
    Comentar
  11. Rival CM4015 Heating Element Replacement: passo 11, imagem 1 %32
    • Remove the 4 springs holding the water tubes by squeezing the 2 prongs together.
    • You may also use pliers for this step if the springs are too strong.
    Pergunte ao FixBot
    Comentar
  12. Rival CM4015 Heating Element Replacement: passo 12, imagem 1 %32
    • Bend the heating element back and forth to wiggle the water tubes loose from the plastic.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 10-6, Livingston Fall 2016 Membro de Cal Poly, Team 10-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G6
5 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 28
Ao todo: 661
