Ir para o conteúdo principal
Rival 16131 Toaster bread grabber spring replacement
O que você precisa
  1. Rival 16131 Toaster bread grabber spring replacement, Shell: passo 1, imagem 1 %32 Rival 16131 Toaster bread grabber spring replacement, Shell: passo 1, imagem 2 %32
    • Make sure the toaster is unplugged before dissembling.
    • Turn the toaster over and remove the rubber bumper feet.
    Pergunte ao FixBot
    Comentar
  2. Rival 16131 Toaster bread grabber spring replacement: passo 2, imagem 1 %32 Rival 16131 Toaster bread grabber spring replacement: passo 2, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove four 12 mm screws at the base of the toaster shell.
    Pergunte ao FixBot
    Comentar
  3. Rival 16131 Toaster bread grabber spring replacement: passo 3, imagem 1 %32 Rival 16131 Toaster bread grabber spring replacement: passo 3, imagem 2 %32 Rival 16131 Toaster bread grabber spring replacement: passo 3, imagem 3 %32
    • With the dial facing you, push the toaster base up and away until the base is just over the lip of the shell. This will disconnect the browning dial from the rest of the toaster.
    • When reassembling the toaster, make sure that the back of the dial lines up with the slot, both in position and orientation (the dial and slot are not perfect circles - they have a notch).
    • The only object holding the shell onto the toaster now is the grey part of the lever.
    Pergunte ao FixBot
    Comentar
  4. Rival 16131 Toaster bread grabber spring replacement: passo 4, imagem 1 %32
    • Reach into the shell and grab the back white part of the lever.
    • Hold the grey lever with both your index finger and middle finger. Next, pull it.
    • Pulling too hard will break the mechanism that holds the grey handle onto the white lever.
    • Remove the shell.
    Pergunte ao FixBot
    Comentar
  5. Rival 16131 Toaster bread grabber spring replacement, Bread Grabber Springs: passo 5, imagem 1 %32
    • Locate the black, diamond shaped spring behind the white lever bracket.
    Pergunte ao FixBot
    Comentar
  6. Rival 16131 Toaster bread grabber spring replacement: passo 6, imagem 1 %32
    Ferramenta utilizada neste passo:
    • To remove the spring, use the tweezers to push the bottom edge of the spring out and around the metal bracket that keeps the springs in place.
    • Repeat this for the other side.
    Pergunte ao FixBot
    Comentar
  7. Rival 16131 Toaster bread grabber spring replacement: passo 7, imagem 1 %32
    • Pulling the bottom of the spring out, lift the left circle up over the metal bracket that extends out from the bread grabbers.
    • Bring the right circle out, down, and around the bracket the extends out from the shelf that the toast would sits on.
    • Remove the right circle.
    Pergunte ao FixBot
    Comentar
  8. Rival 16131 Toaster bread grabber spring replacement: passo 8, imagem 1 %32
    • Make sure that all the angles are similar to the other metal spring.
    • If not, then bend the broken spring to the angles of the correct spring.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Grant Haug
Membro desde: 09/26/12
148 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 2-8, Propen Fall 2012 Membro de Cal Poly, Team 2-8, Propen Fall 2012
CPSU-PROPEN-F12S2G8
5 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 51
Ao todo: 4,536
