Ir para o conteúdo principal
Ring Video Doorbell Camera Replacement
O que você precisa
    1. Ring Video Doorbell  Camera Replacement, Camera: passo 1, imagem 1 %32 Ring Video Doorbell  Camera Replacement, Camera: passo 1, imagem 2 %32 Ring Video Doorbell  Camera Replacement, Camera: passo 1, imagem 3 %32
      • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
      • Pry open the aluminum plate using the Plastic Opening Tool(s).
      • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Ring Video Doorbell  Camera Replacement: passo 2, imagem 1 %32 Ring Video Doorbell  Camera Replacement: passo 2, imagem 2 %32 Ring Video Doorbell  Camera Replacement: passo 2, imagem 3 %32
      • Pry open the back case as shown using the Plastic Opening Tool.
      • Disconnect the battery from motherboard by carefully pulling up on the connector.
      Pergunte ao FixBot
      Comentar
    3. Ring Video Doorbell  Camera Replacement: passo 3, imagem 1 %32 Ring Video Doorbell  Camera Replacement: passo 3, imagem 2 %32 Ring Video Doorbell  Camera Replacement: passo 3, imagem 3 %32
      • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
      • Carefully detach the motherboard, from the housing unit using your hands.
      Pergunte ao FixBot
      Comentar
    4. Ring Video Doorbell  Camera Replacement: passo 4, imagem 1 %32 Ring Video Doorbell  Camera Replacement: passo 4, imagem 2 %32
      • Using the Plating Tool Opener, arefully disconnect the ribbon cable that attaches the camera to the housing.
      • Replace camera, and follow the steps in reverse order to reassemble
      Pergunte ao FixBot
      Comentar
    5. Ring Video Doorbell  Camera Replacement: passo 5, imagem 1 %32 Ring Video Doorbell  Camera Replacement: passo 5, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Unscrew the two 1 mm screws using the PH00 Philips Screwdriver.
      • Detach the black and red wire connected to the motherboard, using the tweezers, to remove the camera.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Isaiah Wilson
Membro desde: 02/20/18
231 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S11-G5, Cheng Spring 2018 Membro de USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 Membros
Autoria de 20 guias
11Comentários do guia
What camera should I use to replace a malfunctioning camera in the ring video doorbell? And where do I buy it?
jonathan.byus - Responder Compartilhar
Bump. What camera should I use to replace? (Scratched Lens.) Is the lens you can touch, a lens, or is it just a cover? Mine fell at there is chip right in the center that make the image unusable.
Bobby Diggins - Responder Compartilhar
I have a scratch dead center of mine too. Have no clue how it got there as I’m super careful when I take it off to charge. Ugh. did you find out where to buy a replacement?
Kim Townsend - Responder Compartilhar
What camera should I use to replace? (Scratched Lens.)  I have the right 1st generation with a 740p camera
meanltltoo - Responder Compartilhar
Has anyone found a replacement camera online?
christina.stewart - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 38
Últimos 30 dias: 174
Ao todo: 20,679
