Ir para o conteúdo principal
Ring Stick Up Cam Camera Replacement
O que você precisa
    1. Ring Stick Up Cam Camera Replacement, Battery: passo 1, imagem 1 %32
      • Remove the six 6mm Phillips #00 screws from the back of the device.
      Pergunte ao FixBot
      Comentar
    2. Ring Stick Up Cam Camera Replacement: passo 2, imagem 1 %32
      • Pry off the aluminum plate using a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    3. Ring Stick Up Cam Camera Replacement: passo 3, imagem 1 %32
      • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
      Pergunte ao FixBot
      Comentar
    4. Ring Stick Up Cam Camera Replacement: passo 4, imagem 1 %32
      • Pry off the back cover using a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    5. Ring Stick Up Cam Camera Replacement: passo 5, imagem 1 %32
      • Disconnect the battery power leads using a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    6. Ring Stick Up Cam Camera Replacement: passo 6, imagem 1 %32
      • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
      Pergunte ao FixBot
      Comentar
    1. Ring Stick Up Cam Camera Replacement, Camera: passo 7, imagem 1 %32
      • Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
      Pergunte ao FixBot
      Comentar
    2. Ring Stick Up Cam Camera Replacement: passo 8, imagem 1 %32
      • Disconnect the ribbon connector shown in the photo.
      Pergunte ao FixBot
      Comentar
    3. Ring Stick Up Cam Camera Replacement: passo 9, imagem 1 %32
      • Remove the motherboard from the device by hand.
      Pergunte ao FixBot
      Comentar
    4. Ring Stick Up Cam Camera Replacement: passo 10, imagem 1 %32
      • Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
      • Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
      Pergunte ao FixBot
      Comentar
    5. Ring Stick Up Cam Camera Replacement: passo 11, imagem 1 %32
      • Remove the three plastic spacers shown in the photo by hand.
      Pergunte ao FixBot
      Comentar
    6. Ring Stick Up Cam Camera Replacement: passo 12, imagem 1 %32
      • Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
      Pergunte ao FixBot
      Comentar
    7. Ring Stick Up Cam Camera Replacement: passo 13, imagem 1 %32
      • Lift the camera board out of the housing using your hand.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Ao Li
Membro desde: 02/06/19
245 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S18-G3, Lore Winter 2019 Membro de UC Davis, Team S18-G3, Lore Winter 2019
UCD-LORE-W19S18G3
3 Membros
Autoria de 8 guias
2Comentários do guia
Where can I purchase a new lens?
Javier Casas - Responder Compartilhar
Any ideas where to get a new lens?
Mete Doguoglu - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 39
Ao todo: 5,370
