Ir para o conteúdo principal
Ring Stick Up Cam Battery Replacement
O que você precisa
    1. Ring Stick Up Cam Battery Replacement, Battery: passo 1, imagem 1 %32
      • Remove the six 6mm Phillips #00 screws from the back of the device.
      Pergunte ao FixBot
      Comentar
    2. Ring Stick Up Cam Battery Replacement: passo 2, imagem 1 %32
      • Pry off the aluminum plate using a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    3. Ring Stick Up Cam Battery Replacement: passo 3, imagem 1 %32
      • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
      Pergunte ao FixBot
      Comentar
    4. Ring Stick Up Cam Battery Replacement: passo 4, imagem 1 %32
      • Pry off the back cover using a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    5. Ring Stick Up Cam Battery Replacement: passo 5, imagem 1 %32
      • Disconnect the battery power leads using a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    6. Ring Stick Up Cam Battery Replacement: passo 6, imagem 1 %32
      • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
      Pergunte ao FixBot
      Comentar
Conclusão
9 outras pessoas executaram este guia.
Equipe
UC Davis, Team S18-G3, Lore Winter 2019 Membro de UC Davis, Team S18-G3, Lore Winter 2019
UCD-LORE-W19S18G3
3 Membros
Autoria de 8 guias
12Comentários do guia
Where can I get a replacement battery?
jbains - Responder Compartilhar
Bad news,
After three different calls to the Ring customer service line (just to be certain i was getting the true honest answer each time) i was told that the Ring stickup 1st generation cam - the one in this section is not available and never was. They suggest that this model was never intended yo be dissected as easy as we know it is. the best we can do is to find someone selling one with a damaged camera and removing its battery. That was how i was able to get my 1st gen stickup back in service again.
Dave S - Responder Compartilhar
No reason to try this, no battery replacement? Have searched the Internet, can’t find a replacement!
Robert Byrum - Responder Compartilhar
Why would they not use the same simple replaceable battery system as the ring doorbell2
Peter Lasnick - Responder Compartilhar
Would love to replace the battery, if I could find it online…
Matthew Grow - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 47
Ao todo: 13,906
