Ir para o conteúdo principal
Ring Stick Up Cam Battery Camera Replacement
O que você precisa
    1. Ring Stick Up Cam Battery Camera Replacement, Battery: passo 1, imagem 1 %32
      • Turn the camera so the lens is facing away from you, and the back is facing towards you.
      • Place one hand securely on the base and the other on the stand.
      • Carefully twist your bottom hand counterclockwise until the indicator line reaches the unlock icon.
      Pergunte ao FixBot
      Comentar
    2. Ring Stick Up Cam Battery Camera Replacement: passo 2, imagem 1 %32
      • Gently pull down to separate the stand from the camera body.
      Pergunte ao FixBot
      Comentar
    3. Ring Stick Up Cam Battery Camera Replacement: passo 3, imagem 1 %32 Ring Stick Up Cam Battery Camera Replacement: passo 3, imagem 2 %32
      • Hold the camera so the opening containing the battery is toward the ceiling.
      • Squeeze the silver lever labeled "push" and extract the battery from its slot.
      Pergunte ao FixBot
      Comentar
    1. Ring Stick Up Cam Battery Camera Replacement, Motherboard: passo 4, imagem 1 %32
      Ferramenta utilizada neste passo:
      Halberd Spudger
      $2.99
      • Remove the upper and lower silicon covers on the rear panel with your fingers or the hook-end of the halberd spudger.
      Pergunte ao FixBot
      Comentar
    2. Ring Stick Up Cam Battery Camera Replacement: passo 5, imagem 1 %32
      • Remove the 6 mm white screw from the rear panel with the a T3 Torx screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Ring Stick Up Cam Battery Camera Replacement: passo 6, imagem 1 %32
      • Rotate the device so the base is facing upward.
      • Remove the two 6 mm screws from the base (on either side of the QR code) using a Phillips #00 screwdriver.
      • Remove the two 4 mm screws that connect the silver latch on the outside rim using a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Ring Stick Up Cam Battery Camera Replacement: passo 7, imagem 1 %32
      • Remove the silver latch from the base.
      • Remove the front cover.
      • Remove the eight 6 mm screws from the inside panel with a Philips #00 screwdriver.
      • Remove the two 4 mm screws from the inside panel with a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    5. Ring Stick Up Cam Battery Camera Replacement: passo 8, imagem 1 %32
      • Pry the inside panel open using your hands or a spudger if necessary.
      Pergunte ao FixBot
      Comentar
    6. Ring Stick Up Cam Battery Camera Replacement: passo 9, imagem 1 %32
      • Remove the seven 4 mm screws connecting the motherboard to the camera body with a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    7. Ring Stick Up Cam Battery Camera Replacement: passo 10, imagem 1 %32 Ring Stick Up Cam Battery Camera Replacement: passo 10, imagem 2 %32
      • Lift the motherboard from the camera body with the halberd spudger.
      Pergunte ao FixBot
      Comentar
    8. Ring Stick Up Cam Battery Camera Replacement: passo 11, imagem 1 %32 Ring Stick Up Cam Battery Camera Replacement: passo 11, imagem 2 %32
      • Rotate the device to its side.
      • With your fingers, carefully remove the white part of the cord clip from the beige base.
      • Repeat this for the remaining three cords connecting the motherboard to the camera body.
      Pergunte ao FixBot
      Comentar
    9. Ring Stick Up Cam Battery Camera Replacement: passo 12, imagem 1 %32
      • Fold the motherboard downward from the camera body, revealing a white connecting strip.
      • Using the flat end of a spudger, flick the black hinge upward.
      • Pull the white strip out of the slot.
      Pergunte ao FixBot
      Comentar
    10. Ring Stick Up Cam Battery Camera Replacement: passo 13, imagem 1 %32 Ring Stick Up Cam Battery Camera Replacement: passo 13, imagem 2 %32
      • Carefully insert the spudger underneath gold adhesive at the lower left-hand corner of the motherboard.
      • Gently remove the adhesive cover from the motherboard.
      Pergunte ao FixBot
      Comentar
    1. Ring Stick Up Cam Battery Camera Replacement, Camera: passo 14, imagem 1 %32
      • Orient your device so that the interior of the camera body is facing the ceiling.
      Pergunte ao FixBot
      Comentar
    2. Ring Stick Up Cam Battery Camera Replacement: passo 15, imagem 1 %32
      • Remove the two 6 mm screws that connect the camera to the camera body using a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Ring Stick Up Cam Battery Camera Replacement: passo 16, imagem 1 %32
      • Grab and twist the camera counterclockwise with your thumb and index finger.
      Pergunte ao FixBot
      Comentar
    4. Ring Stick Up Cam Battery Camera Replacement: passo 17, imagem 1 %32 Ring Stick Up Cam Battery Camera Replacement: passo 17, imagem 2 %32
      • Using your fingers, lift out the camera component including the camera lens and the attached wire.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Nick Tomkins
Membro desde: 02/24/23
124 Reputação
Autoria de 1 guia
Equipe
Marist, Team 1-1, Chaterdon Spring 2023 Membro de Marist, Team 1-1, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G1
3 Membros
Autoria de 8 guias
1Comentário do guia
Seriously where do you get the part
Tonio Lopez (Tony) - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 105
Ao todo: 7,638
