Ir para o conteúdo principal
Ridgid R86034 LED Replacement
O que você precisa
  1. Ridgid R86034 LED Replacement, Housing: passo 1, imagem 1 %32
    • Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
    • Use some force; the rubber cover is securely attached to the housing.
    • Rotate the casing until it fits onto the housing with no gaps between it and the clear cover.
    • Make sure the casing is properly oriented onto the housing. Orientation is important here.
    Pergunte ao FixBot
    Comentar
  2. Ridgid R86034 LED Replacement: passo 2, imagem 1 %32 Ridgid R86034 LED Replacement: passo 2, imagem 2 %32
    • Remove the plastic cover with your hands. It should come off fairly easily.
    Pergunte ao FixBot
    Comentar
  3. Ridgid R86034 LED Replacement: passo 3, imagem 1 %32 Ridgid R86034 LED Replacement: passo 3, imagem 2 %32 Ridgid R86034 LED Replacement: passo 3, imagem 3 %32
    • Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver.
    • Use a firm grip to peel off the back panel. It is sealed tight and requires a good amount of force to remove.
    Pergunte ao FixBot
    Comentar
  4. Ridgid R86034 LED Replacement: passo 4, imagem 1 %32 Ridgid R86034 LED Replacement: passo 4, imagem 2 %32
    • Unscrew the eight 15 mm T10 Torx screws from the housing
    • The screw hole located nearest the battery port is deep and small. Most screwdrivers with replaceable bits will not fit into the hole. Instead, use a conventional screwdriver that fits.
    Pergunte ao FixBot
    Comentar
  5. Ridgid R86034 LED Replacement: passo 5, imagem 1 %32
    • Place the driver flat on a table before completely separating the two halves of the housing so components of the drill don't fall out during opening.
    • Pry apart the two halves of the housing at the back side of the driver using the metal spudger. The housing is easier to remove if you pry from both sides.
    Pergunte ao FixBot
    Comentar
  6. Ridgid R86034 LED Replacement: passo 6, imagem 1 %32 Ridgid R86034 LED Replacement: passo 6, imagem 2 %32
    • Do not remove the direction switch.
    • Pull out all electrical components from housing by hand. The components should require little force to lift out.
    • Lift out the motor.
    • Follow the wires.
    • The circuit board located nearest the battery pack and the LED light will be hard to pull out.
    • Remember to precisely place all components in their correct slots with their correct orientations when reassembling.
    Pergunte ao FixBot
    Comentar
  7. Ridgid R86034 LED Replacement, LED: passo 7, imagem 1 %32
    • Identify the LED light. The LED light is the component with clear casing and has two wires attached, located toward the bottom of the driver.
    Pergunte ao FixBot
    Comentar
  8. Ridgid R86034 LED Replacement: passo 8, imagem 1 %32 Ridgid R86034 LED Replacement: passo 8, imagem 2 %32 Ridgid R86034 LED Replacement: passo 8, imagem 3 %32
    • Cut the pink and white wires attached to the LED at a point that is a little more than 1/4 inch from the LED.
    Pergunte ao FixBot
    Comentar
  9. Ridgid R86034 LED Replacement: passo 9, imagem 1 %32
    • Strip the wires back about 1/4 inch on the LED.
    Pergunte ao FixBot
    Comentar
  10. Ridgid R86034 LED Replacement: passo 10, imagem 1 %32 Ridgid R86034 LED Replacement: passo 10, imagem 2 %32
    • Strip the wires that were connected to the LED on the circuit board to approximately 1/4 inch.
    Pergunte ao FixBot
    Comentar
  11. Ridgid R86034 LED Replacement: passo 11, imagem 1 %32
    • Solder the new LED striped wires to the wire attached to the circuit board.
    • Wrap the soldered connection with electrical tape, to ensure that the circuit isn't shorted.
    Pergunte ao FixBot
    Comentar
Conclusão
Sean Liston
Membro desde: 04/28/15
311 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 15-5, Amido Spring 2015 Membro de Cal Poly, Team 15-5, Amido Spring 2015
CPSU-AMIDO-S15S15G5
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 1,660
