Ir para o conteúdo principal
Ridgid R86034 Direction Switch Replacement
O que você precisa
  1. Ridgid R86034 Direction Switch Replacement, Housing: passo 1, imagem 1 %32
    • Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
    • Use some force; the rubber cover is securely attached to the housing.
    • Rotate the casing until it fits onto the housing with no gaps between it and the clear cover.
    • Make sure the casing is properly oriented onto the housing. Orientation is important here.
    Pergunte ao FixBot
    Comentar
  2. Ridgid R86034 Direction Switch Replacement: passo 2, imagem 1 %32 Ridgid R86034 Direction Switch Replacement: passo 2, imagem 2 %32
    • Remove the plastic cover with your hands. It should come off fairly easily.
    Pergunte ao FixBot
    Comentar
  3. Ridgid R86034 Direction Switch Replacement: passo 3, imagem 1 %32 Ridgid R86034 Direction Switch Replacement: passo 3, imagem 2 %32 Ridgid R86034 Direction Switch Replacement: passo 3, imagem 3 %32
    • Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver.
    • Use a firm grip to peel off the back panel. It is sealed tight and requires a good amount of force to remove.
    Pergunte ao FixBot
    Comentar
  4. Ridgid R86034 Direction Switch Replacement: passo 4, imagem 1 %32 Ridgid R86034 Direction Switch Replacement: passo 4, imagem 2 %32
    • Unscrew the eight 15 mm T10 Torx screws from the housing
    • The screw hole located nearest the battery port is deep and small. Most screwdrivers with replaceable bits will not fit into the hole. Instead, use a conventional screwdriver that fits.
    Pergunte ao FixBot
    Comentar
  5. Ridgid R86034 Direction Switch Replacement: passo 5, imagem 1 %32
    • Place the driver flat on a table before completely separating the two halves of the housing so components of the drill don't fall out during opening.
    • Pry apart the two halves of the housing at the back side of the driver using the metal spudger. The housing is easier to remove if you pry from both sides.
    Pergunte ao FixBot
    Comentar
  6. Ridgid R86034 Direction Switch Replacement: passo 6, imagem 1 %32 Ridgid R86034 Direction Switch Replacement: passo 6, imagem 2 %32
    • Do not remove the direction switch.
    • Pull out all electrical components from housing by hand. The components should require little force to lift out.
    • Lift out the motor.
    • Follow the wires.
    • The circuit board located nearest the battery pack and the LED light will be hard to pull out.
    • Remember to precisely place all components in their correct slots with their correct orientations when reassembling.
    Pergunte ao FixBot
    Comentar
  7. Ridgid R86034 Direction Switch Replacement, Direction Switch: passo 7, imagem 1 %32
    Pergunte ao FixBot
    Comentar
Conclusão
Sean Liston
Membro desde: 04/28/15
311 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 15-5, Amido Spring 2015 Membro de Cal Poly, Team 15-5, Amido Spring 2015
CPSU-AMIDO-S15S15G5
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 60
Ao todo: 2,233
