Introdução
A defective drill trigger can unintentionally keep the drill on when used by operators and this safety hazard increases the chances of accidental punctures to nearby objects.
O que você precisa
Eject the battery from the drill.
Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
