Ir para o conteúdo principal
Ridgid R82005 Trigger Switch Replacement
O que você precisa
  1. Ridgid R82005 Trigger Switch Replacement, Trigger Switch: passo 1, imagem 1 %32
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
    • Unscrew the M5x18.5mm screw if belt clip is attached.
  2. Ridgid R82005 Trigger Switch Replacement: passo 2, imagem 1 %32
    • Push the metallic Housing Connecting clip out with flat side of the plastic spudger.
    • Eject battery before attempting this step.
  3. Ridgid R82005 Trigger Switch Replacement: passo 3, imagem 1 %32 Ridgid R82005 Trigger Switch Replacement: passo 3, imagem 2 %32 Ridgid R82005 Trigger Switch Replacement: passo 3, imagem 3 %32
    • Remove the top half of the Housing Assembly.
    • Keep track of where the wires lead from the motor assembly to trigger switch.
    • Remove all internal components.
  4. Ridgid R82005 Trigger Switch Replacement: passo 4, imagem 1 %32 Ridgid R82005 Trigger Switch Replacement: passo 4, imagem 2 %32 Ridgid R82005 Trigger Switch Replacement: passo 4, imagem 3 %32
    • Motor Assembly/Gearbox and Trigger Switch removed from Housing Assembly.
    • Desolder the black wire connected to the motor.
    • Flip Trigger Switch and desolder red wire.
    • To learn how to solder, use our How to Solder and Desolder Connections guide.
Conclusão
Alex Cominos
Membro desde: 02/14/19
376 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S1-G2, Leahy Spring 2019 Membro de USF Tampa, Team S1-G2, Leahy Spring 2019
USFT-LEAHY-S19S1G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 435
