Introdução
This guide is for cord replacement on the Rigid JobMax R2851 Series B. This would be helpful if you have been noticing sudden starting and stopping of the tool or a jittery operation. If the tool has stopped working completely and you find the motor and the brushes are in good condition.
This repair requires minimal tools listed in the guide, and can be done in a short amount of time. Additionally you should remember to unplug your device before starting any repairs to avoid risk of being electrocuted.
O que você precisa
Orient the device so that the trigger is facing downwards.
Place your thumb and index finger on the two buttons located on the head of the tool.
Press the two buttons in and pull the head of the tool off.
Pinch the brush and pry upward away from the center of the part to remove from the device.
