Introdução
For this repair you will need:
- T20 Star Bit Screwdriver
- J1 Philips Head Screwdriver
- Prybar
- Soldering Iron
To replace the motor in a Ridgid GEN5X R8642, you will need to take the saw apart into two. The screws are M4 X 16 mm (Part Number: 089041033083) and M4 x 25mm (Part Number: 660208093). Next the switch assembly must be desoldered in order to replace the motor. All parts can be found on the parts catalog link in the device page.
O que você precisa
Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
Remove the plastic wire covers to the red and black connections on the switch assembly.
Desolder the connections on both the red and black wire using a soldering iron.
Once the solder is removed, pull out the wires with the battery port attached to the wires.
To reassemble your device follow these instructions in reverse order.
