Introdução
This guide will show you how to remove the handle of the Ricoh Super 8 camera. You may wish to do this if you need to replace the handle. To reattach or replace the handle, follow these steps in reverse order.
In Step 6, you will remove the handle itself. This will require you to desolder the wire connections in the handle. To attach a new handle, you will need to re-solder these connections back into place.
Make sure your camera is fully powered off before you begin.
O que você precisa
Open the handle's battery compartment and remove the batteries from the handle.
