Ir para o conteúdo principal
Ricoh Shotmaster 130Z Battery Replacement
O que você precisa
  1. Ricoh Shotmaster 130Z Battery Replacement, Battery: passo 1, imagem 1 %32
    • First, make sure that the camera is turned off. The dial must line up the word "off" with the white tally mark.
    Pergunte ao FixBot
  2. Ricoh Shotmaster 130Z Battery Replacement: passo 2, imagem 1 %32 Ricoh Shotmaster 130Z Battery Replacement: passo 2, imagem 2 %32
    • You can find the battery compartment on the side of the camera. Search for the arrow and the abreviation "BATT"
    • Stick your finger nail (or a blue opening tool if you wish) in the notch and flip open the door to expose the battery compartment.
    Pergunte ao FixBot
  3. Ricoh Shotmaster 130Z Battery Replacement: passo 3, imagem 1 %32 Ricoh Shotmaster 130Z Battery Replacement: passo 3, imagem 2 %32 Ricoh Shotmaster 130Z Battery Replacement: passo 3, imagem 3 %32
    • The yellow latch holds down an extra cover for the batteries
    • Push on it in to open the compartment
    • Insert batteries according to the charges marked on the inside part of the cover
    Pergunte ao FixBot
Conclusão
tcalvin12
Membro desde: 10/25/16
153 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 3-4, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 3-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G4
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 64
Ao todo: 1,091
