Ir para o conteúdo principal
Rexing V1P Plus Rear Camera Replacement
O que você precisa
    1. Rexing V1P Plus Rear Camera Replacement, Rear Camera: passo 1, imagem 1 %32 Rexing V1P Plus Rear Camera Replacement, Rear Camera: passo 1, imagem 2 %32 Rexing V1P Plus Rear Camera Replacement, Rear Camera: passo 1, imagem 3 %32
      • Begin by orienting the rear camera lens facing up.
      • Twist the adhesive mount surface parallel to the camera lens.
      • Pull the mounting ring axially away from the camera case.
      Pergunte ao FixBot
      Comentar
    2. Rexing V1P Plus Rear Camera Replacement: passo 2, imagem 1 %32 Rexing V1P Plus Rear Camera Replacement: passo 2, imagem 2 %32 Rexing V1P Plus Rear Camera Replacement: passo 2, imagem 3 %32
      • Locate the small indentation on the camera case previously covered by the mounting ring.
      • Insert a spudger in the case seam and twist it to lever open the camera case.
      • Use the spudger to pry the case the rest of the way open.
      • Remove the top casing from the rear camera.
      Pergunte ao FixBot
      Comentar
    3. Rexing V1P Plus Rear Camera Replacement: passo 3, imagem 1 %32 Rexing V1P Plus Rear Camera Replacement: passo 3, imagem 2 %32
      • Remove the camera and camera motherboard from the casing.
      • Flip the camera board over revealing the two 3.5 mm screws on the back holding the rear camera to the board.
      Pergunte ao FixBot
      Comentar
    4. Rexing V1P Plus Rear Camera Replacement: passo 4, imagem 1 %32 Rexing V1P Plus Rear Camera Replacement: passo 4, imagem 2 %32 Rexing V1P Plus Rear Camera Replacement: passo 4, imagem 3 %32
      • Remove the two 3.5 mm screws securing the camera to the motherboard using the Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    5. Rexing V1P Plus Rear Camera Replacement: passo 5, imagem 1 %32
      • With the screws removed, the rear camera can be separated from the motherboard.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 28
Ao todo: 639
