Ir para o conteúdo principal
Rexing V1P Plus Motherboard Replacement
O que você precisa
  1. Rexing V1P Plus Motherboard Replacement, Front Camera: passo 1, imagem 1 %32 Rexing V1P Plus Motherboard Replacement, Front Camera: passo 1, imagem 2 %32 Rexing V1P Plus Motherboard Replacement, Front Camera: passo 1, imagem 3 %32
    • Begin by orienting the device with the LCD screen facing down.
    • Remove the four 6 mm screws, located on the backside of the device, using the Phillips #00 screwdriver.
  2. Rexing V1P Plus Motherboard Replacement: passo 2, imagem 1 %32 Rexing V1P Plus Motherboard Replacement: passo 2, imagem 2 %32 Rexing V1P Plus Motherboard Replacement: passo 2, imagem 3 %32
    • Remove the back cover of the device and place it to the side.
    • Rotate the device 180 degrees to where the camera is facing you.
  3. Rexing V1P Plus Motherboard Replacement: passo 3, imagem 1 %32 Rexing V1P Plus Motherboard Replacement: passo 3, imagem 2 %32 Rexing V1P Plus Motherboard Replacement: passo 3, imagem 3 %32
    • Remove the two 5 mm screws next to the lens using the Phillips #00 screwdriver.
  4. Rexing V1P Plus Motherboard Replacement: passo 4, imagem 1 %32 Rexing V1P Plus Motherboard Replacement: passo 4, imagem 2 %32 Rexing V1P Plus Motherboard Replacement: passo 4, imagem 3 %32
    • Remove the two camera angle adjusters from the side of the device and carefully pull out the lens.
  5. Rexing V1P Plus Motherboard Replacement: passo 5, imagem 1 %32 Rexing V1P Plus Motherboard Replacement: passo 5, imagem 2 %32 Rexing V1P Plus Motherboard Replacement: passo 5, imagem 3 %32
    • Remove the two 5mm screws securing the camera support bracket using the Phillips #00 screwdriver.
  6. Rexing V1P Plus Motherboard Replacement: passo 6, imagem 1 %32 Rexing V1P Plus Motherboard Replacement: passo 6, imagem 2 %32 Rexing V1P Plus Motherboard Replacement: passo 6, imagem 3 %32
    • Carefully remove the plastic frame piece from its previously secured position on the motherboard.
    • It will rest loosely around the white camera ribbon.
    • Rotate the device 180 degrees to where the camera is facing away from you.
  7. Rexing V1P Plus Motherboard Replacement: passo 7, imagem 1 %32 Rexing V1P Plus Motherboard Replacement: passo 7, imagem 2 %32 Rexing V1P Plus Motherboard Replacement: passo 7, imagem 3 %32
    • Carefully peel back the adhesive material covering the ribbon cable connection.
  8. Rexing V1P Plus Motherboard Replacement: passo 8, imagem 1 %32 Rexing V1P Plus Motherboard Replacement: passo 8, imagem 2 %32 Rexing V1P Plus Motherboard Replacement: passo 8, imagem 3 %32
    • Using the Flathead 1.5mm screwdriver, or another pry tool, gently flip up the black ZIF connector locking flap to free the ribbon cable.
    • Once the connector is open, slide the ribbon cable out to remove it.
  9. Rexing V1P Plus Motherboard Replacement, Motherboard: passo 9, imagem 1 %32 Rexing V1P Plus Motherboard Replacement, Motherboard: passo 9, imagem 2 %32 Rexing V1P Plus Motherboard Replacement, Motherboard: passo 9, imagem 3 %32
    • Using a soldering iron, disconnect the four wires connected to the motherboard.
  10. Rexing V1P Plus Motherboard Replacement: passo 10, imagem 1 %32 Rexing V1P Plus Motherboard Replacement: passo 10, imagem 2 %32 Rexing V1P Plus Motherboard Replacement: passo 10, imagem 3 %32
    • Using the Phillips #00 screwdriver, remove the three 3.5 mm screws securing the motherboard to the case.
  11. Rexing V1P Plus Motherboard Replacement: passo 11, imagem 1 %32 Rexing V1P Plus Motherboard Replacement: passo 11, imagem 2 %32 Rexing V1P Plus Motherboard Replacement: passo 11, imagem 3 %32
    • Pull the black antenna wire with the gold cap straight up to disconnect it from the motherboard.
    • Using your fingers, spread the case apart to provide space for the motherboard to be removed.
    • This must be done to free the connected ports from their mounting locations in the case.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 330
