Ir para o conteúdo principal
Revlon RVDR5061 Fan/Motor Assembly Replacement
O que você precisa
  1. Revlon RVDR5061 Fan/Motor Assembly Replacement, Fan/Motor Assembly: passo 1, imagem 1 %32
    • Using a Phillips #3 screwdriver, remove the single 25 mm Phillips head screw in the handle by turning it counterclockwise.
  2. Revlon RVDR5061 Fan/Motor Assembly Replacement: passo 2, imagem 1 %32
    • Using a medium flathead screwdriver or better yet iFixit plastic opening tools, gently pry apart the handle from the power cord.
  3. Revlon RVDR5061 Fan/Motor Assembly Replacement: passo 3, imagem 1 %32
    • After pulling apart the housing, all internals will be free to remove.
  4. Revlon RVDR5061 Fan/Motor Assembly Replacement: passo 4, imagem 1 %32 Revlon RVDR5061 Fan/Motor Assembly Replacement: passo 4, imagem 2 %32 Revlon RVDR5061 Fan/Motor Assembly Replacement: passo 4, imagem 3 %32
    • The fan/motor assembly is connected to the heating element assembly at two points need to be desoldered. After pulling the attached wires through the holes the fan/motor assembly will be free from the heating element assembly. Congratulations you have now completely removed the fan/motor assembly from this hair dryer!
Conclusão
Curtis
Membro desde: 07/11/18
159 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S2-G2, Wilson Summer 2018 Membro de IUPUI, Team S2-G2, Wilson Summer 2018
IUPUI-WILSON-SU18S2G2
Membros da 4
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 1,074
