Ir para o conteúdo principal
Retroid Pocket 3 Trigger Button Replacement
O que você precisa
    1. Retroid Pocket 3 Trigger Button Replacement, Battery: passo 1, imagem 1 %32
      • Unplug any cables connected to the Retroid Pocket 3+.
      • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
      Pergunte ao FixBot
      Comentar
    2. Retroid Pocket 3 Trigger Button Replacement: passo 2, imagem 1 %32 Retroid Pocket 3 Trigger Button Replacement: passo 2, imagem 2 %32 Retroid Pocket 3 Trigger Button Replacement: passo 2, imagem 3 %32
      • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
      • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
      Pergunte ao FixBot
      Comentar
    3. Retroid Pocket 3 Trigger Button Replacement: passo 3, imagem 1 %32 Retroid Pocket 3 Trigger Button Replacement: passo 3, imagem 2 %32
      • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
      • Lift off the metal plate.
      Pergunte ao FixBot
      Comentar
    4. Retroid Pocket 3 Trigger Button Replacement: passo 4, imagem 1 %32 Retroid Pocket 3 Trigger Button Replacement: passo 4, imagem 2 %32 Retroid Pocket 3 Trigger Button Replacement: passo 4, imagem 3 %32
      • Use a plastic opening tool or spudger to unclip the battery connector.
      • Carefully lift the battery from the case.
      • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
      • Lift and remove the battery.
      Pergunte ao FixBot
      Comentar
    1. Retroid Pocket 3 Trigger Button Replacement, Trigger Button: passo 5, imagem 1 %32 Retroid Pocket 3 Trigger Button Replacement, Trigger Button: passo 5, imagem 2 %32 Retroid Pocket 3 Trigger Button Replacement, Trigger Button: passo 5, imagem 3 %32
      • Using the spudger, put the tip under the top round clip at the top.
      • Carefully start lifting the clip to slide it off the plastic pin on the case, tilting the trigger button as you lift it to remove.
      Pergunte ao FixBot
      Comentar
    2. Retroid Pocket 3 Trigger Button Replacement: passo 6, imagem 1 %32 Retroid Pocket 3 Trigger Button Replacement: passo 6, imagem 2 %32 Retroid Pocket 3 Trigger Button Replacement: passo 6, imagem 3 %32
      • Remove the six 4.4 mm screws on the trigger buttons with a Phillips #00 screwdriver.
      • Gently pull the trigger button through until it has come undone.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 24
Últimos 30 dias: 90
Ao todo: 1,648
