Ir para o conteúdo principal
Retroid Pocket 3 LCD Screen Replacement
O que você precisa
  1. Retroid Pocket 3 LCD Screen Replacement, Battery: passo 1, imagem 1 %32
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    Pergunte ao FixBot
    Comentar
  2. Retroid Pocket 3 LCD Screen Replacement: passo 2, imagem 1 %32 Retroid Pocket 3 LCD Screen Replacement: passo 2, imagem 2 %32 Retroid Pocket 3 LCD Screen Replacement: passo 2, imagem 3 %32
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    Pergunte ao FixBot
    Comentar
  3. Retroid Pocket 3 LCD Screen Replacement: passo 3, imagem 1 %32 Retroid Pocket 3 LCD Screen Replacement: passo 3, imagem 2 %32
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    Pergunte ao FixBot
    Comentar
  4. Retroid Pocket 3 LCD Screen Replacement: passo 4, imagem 1 %32 Retroid Pocket 3 LCD Screen Replacement: passo 4, imagem 2 %32 Retroid Pocket 3 LCD Screen Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    Pergunte ao FixBot
    Comentar
  5. Retroid Pocket 3 LCD Screen Replacement, Motherboard: passo 5, imagem 1 %32
    • Remove the three 4.5 mm screws with a Phillips #00 screwdriver on the main board.
    Pergunte ao FixBot
    Comentar
  6. Retroid Pocket 3 LCD Screen Replacement: passo 6, imagem 1 %32
    • Using a spudger, put the tip under the aerial connecter and rotate upwards to unclip the plug.
    Pergunte ao FixBot
    Comentar
  7. Retroid Pocket 3 LCD Screen Replacement: passo 7, imagem 1 %32
    • Unclip and remove the one ribbon cable on the left.
    Pergunte ao FixBot
    Comentar
  8. Retroid Pocket 3 LCD Screen Replacement: passo 8, imagem 1 %32
    • Use a spudger to unclip and remove the two ribbon cables on the right side.
    Pergunte ao FixBot
    Comentar
  9. Retroid Pocket 3 LCD Screen Replacement: passo 9, imagem 1 %32 Retroid Pocket 3 LCD Screen Replacement: passo 9, imagem 2 %32
    • Use a spudger to disconnect the two speaker cables on the bottom of the board.
    Pergunte ao FixBot
    Comentar
  10. Retroid Pocket 3 LCD Screen Replacement: passo 10, imagem 1 %32 Retroid Pocket 3 LCD Screen Replacement: passo 10, imagem 2 %32 Retroid Pocket 3 LCD Screen Replacement: passo 10, imagem 3 %32
    • Start lifting the board to give you access to the vibration motor on the metal case.
    • Use a spudger to carefully pry the motor free; it is bound with double-sided tape.
    • Carefully lift the board out of the device.
    Pergunte ao FixBot
    Comentar
  11. Retroid Pocket 3 LCD Screen Replacement, Button Pad: passo 11, imagem 1 %32 Retroid Pocket 3 LCD Screen Replacement, Button Pad: passo 11, imagem 2 %32 Retroid Pocket 3 LCD Screen Replacement, Button Pad: passo 11, imagem 3 %32
    • Undo the ribbon cable clips using the Spudger tool.
    • Unclip the cable on the left side of the board.
    • Carefully lift the ribbon cable to the right to remove it from the clip.
    Pergunte ao FixBot
    Comentar
  12. Retroid Pocket 3 LCD Screen Replacement: passo 12, imagem 1 %32 Retroid Pocket 3 LCD Screen Replacement: passo 12, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the three 5.9 mm screws from the controller board.
    Pergunte ao FixBot
    Comentar
  13. Retroid Pocket 3 LCD Screen Replacement: passo 13, imagem 1 %32 Retroid Pocket 3 LCD Screen Replacement: passo 13, imagem 2 %32
    • Using the Spudger tool, put the tip under the edge of the rubber button pad to start lifting it.
    • Button pad will loosen and lift straight out of the casing.
    Pergunte ao FixBot
    Comentar
  14. Retroid Pocket 3 LCD Screen Replacement: passo 14, imagem 1 %32
    • Move to the right side of the device.
    • Using a spudger, undo the ribbon cable clip connected to the main PCB along with the joystick ribbon cable.
    Pergunte ao FixBot
    Comentar
  15. Retroid Pocket 3 LCD Screen Replacement: passo 15, imagem 1 %32 Retroid Pocket 3 LCD Screen Replacement: passo 15, imagem 2 %32 Retroid Pocket 3 LCD Screen Replacement: passo 15, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the two 5.9 mm screws.
    Pergunte ao FixBot
    Comentar
  16. Retroid Pocket 3 LCD Screen Replacement: passo 16, imagem 1 %32 Retroid Pocket 3 LCD Screen Replacement: passo 16, imagem 2 %32 Retroid Pocket 3 LCD Screen Replacement: passo 16, imagem 3 %32
    • Carefully pry up the silicone button pad with a Spudger tool.
    Pergunte ao FixBot
    Comentar
  17. Retroid Pocket 3 LCD Screen Replacement, Trigger Button: passo 17, imagem 1 %32 Retroid Pocket 3 LCD Screen Replacement, Trigger Button: passo 17, imagem 2 %32 Retroid Pocket 3 LCD Screen Replacement, Trigger Button: passo 17, imagem 3 %32
    • Using the spudger, put the tip under the top round clip at the top.
    • Carefully start lifting the clip to slide it off the plastic pin on the case, tilting the trigger button as you lift it to remove.
    Pergunte ao FixBot
    Comentar
  18. Retroid Pocket 3 LCD Screen Replacement: passo 18, imagem 1 %32 Retroid Pocket 3 LCD Screen Replacement: passo 18, imagem 2 %32 Retroid Pocket 3 LCD Screen Replacement: passo 18, imagem 3 %32
    • Remove the six 4.4 mm screws on the trigger buttons with a Phillips #00 screwdriver.
    • Gently pull the trigger button through until it has come undone.
    Pergunte ao FixBot
    Comentar
  19. Retroid Pocket 3 LCD Screen Replacement, LCD Screen: passo 19, imagem 1 %32 Retroid Pocket 3 LCD Screen Replacement, LCD Screen: passo 19, imagem 2 %32 Retroid Pocket 3 LCD Screen Replacement, LCD Screen: passo 19, imagem 3 %32
    • Using the Spudger tool, remove the two speakers at the bottom of the device by gently prying them out.
    • Speakers are held by double-sided tape.
    Pergunte ao FixBot
    Comentar
  20. Retroid Pocket 3 LCD Screen Replacement: passo 20, imagem 1 %32 Retroid Pocket 3 LCD Screen Replacement: passo 20, imagem 2 %32 Retroid Pocket 3 LCD Screen Replacement: passo 20, imagem 3 %32
    • Remove the joysticks by unscrewing the two 3.5mm screws with a Phillips #00 screwdriver.
    • Remove the metal backplate from the front casing of the device by unscrewing the ten 3.5mm screws using the Phillips #00 screwdriver.
    • Carefully lift the ribbon cable from the metal backplate
    Pergunte ao FixBot
    Comentar
Conclusão
Troy
Membro desde: 02/08/24
85 Reputação
Autoria de 1 guia
1Comentário do guia
Hello. Can you tell where I can find a new replacement screen?
Aliaksandr - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 24
Últimos 30 dias: 100
Ao todo: 2,482
