Introdução
If your controller(s) malfunction, you can replace the circuit boards. You only need a Phillips #1 screwdriver.
O que você precisa
With the controller on its face, remove the five 6 mm Phillips #1 screws.
After removing the screws, carefully lift the controller casing .
