Ir para o conteúdo principal
Retro-Bit Retro Duo Cartridge Doors Replacement
O que você precisa
  1. Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: passo 1, imagem 1 %32 Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: passo 1, imagem 2 %32 Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: passo 1, imagem 3 %32
    • With the console on its top. Remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one or more of the screws. Remove it before the screws.
    • Flip the console on its feet, pinch near the AV/S ports, and carefully lift the top casing.
    • Do not completely remove the top casing. There is a small LED circuit board connected to the main circuit board.
    Pergunte ao FixBot
    Comentar
  2. Retro-Bit Retro Duo Cartridge Doors Replacement: passo 2, imagem 1 %32 Retro-Bit Retro Duo Cartridge Doors Replacement: passo 2, imagem 2 %32 Retro-Bit Retro Duo Cartridge Doors Replacement: passo 2, imagem 3 %32
    • Remove the one 6 mm Phillips #0 screw.
    • Lift the top case and set aside.
    Pergunte ao FixBot
    Comentar
  3. Retro-Bit Retro Duo Cartridge Doors Replacement: passo 3, imagem 1 %32 Retro-Bit Retro Duo Cartridge Doors Replacement: passo 3, imagem 2 %32 Retro-Bit Retro Duo Cartridge Doors Replacement: passo 3, imagem 3 %32
    • Remove the eight 10 mm Phillips #0 screws.
    • The cartridge doors are spring-loaded and may pop up.
    Pergunte ao FixBot
    Comentar
  4. Retro-Bit Retro Duo Cartridge Doors Replacement: passo 4, imagem 1 %32 Retro-Bit Retro Duo Cartridge Doors Replacement: passo 4, imagem 2 %32
    • Carefully lift the cartridge door case and set aside.
    Pergunte ao FixBot
    Comentar
  5. Retro-Bit Retro Duo Cartridge Doors Replacement: passo 5, imagem 1 %32 Retro-Bit Retro Duo Cartridge Doors Replacement: passo 5, imagem 2 %32
    • Take the cartridge doors out of the top casing.
    • Keep the correct cartridge doors together. Note the door numbers and position.
    • Doors numbered two and four are for NES cartridges.
    • Doors numbered three are for SNES cartridges.
    Pergunte ao FixBot
    Comentar
Conclusão
Truong Vo
Membro desde: 09/25/17
324 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S4-G4, Eyestone Fall 2017 Membro de USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 31
Ao todo: 1,019
