Ir para o conteúdo principal
Resetting the Clock
  1. Resetting the Clock, Resetting the Clock: passo 1, imagem 1 %32
    • Locate the buttons named "SET", "SKIP", "VOLUME -", and "VOLUME +", which are situated on the top portion of the Nextplay NP109CR.
    Pergunte ao FixBot
    Comentar
  2. Resetting the Clock: passo 2, imagem 1 %32 Resetting the Clock: passo 2, imagem 2 %32
    • Press the "SET" button, the first button from the left in the row located behind the pink snooze bar, three (3) times until the clock display is flashing.
    Pergunte ao FixBot
    Comentar
  3. Resetting the Clock: passo 3, imagem 1 %32
    • Press the "SKIP" button with the two triangles next to it pointing to the right to advance the hour.
    Pergunte ao FixBot
    Comentar
  4. Resetting the Clock: passo 4, imagem 1 %32
    • Press the "SKIP" button with the two triangles pointing to the left to retreat the hour.
    Pergunte ao FixBot
    Comentar
  5. Resetting the Clock: passo 5, imagem 1 %32
    • Press the "VOLUME +" button to advance the minutes forward.
    Pergunte ao FixBot
    Comentar
  6. Resetting the Clock: passo 6, imagem 1 %32
    • Press the "VOLUME -" button to decrease the minutes.
    Pergunte ao FixBot
    Comentar
Conclusão
Once the desired time has been set, the display will continue flashing for about five (5) seconds. When the clock has stopped flashing the clock has been reset successfully. Setting the clock can be very useful when traveling or when living in an area with frequent power outages.
Jacob Aube
Membro desde: 09/24/12
1 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 7-50, Forte Fall 2012 Membro de Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 1,819
