Ir para o conteúdo principal
Replacing an LED Light Fixture
O que você precisa
  1. Replacing an LED Light Fixture, LED Light Fixture: passo 1, imagem 1 %32 Replacing an LED Light Fixture, LED Light Fixture: passo 1, imagem 2 %32 Replacing an LED Light Fixture, LED Light Fixture: passo 1, imagem 3 %32
    • Set up a ladder under the light fixture, and remove the three thumb screws holding up the fixture's cover.
    • Hold the light cover with your free hand while you unscrew the last two screws.
    Pergunte ao FixBot
    Comentar
  2. Replacing an LED Light Fixture: passo 2, imagem 1 %32 Replacing an LED Light Fixture: passo 2, imagem 2 %32
    • Do not remove the base of the light fixture.
    • Check that the light fixture is receiving power with a voltage detector pen.
    • If the light of the voltage detector turns from green to red and makes a loud noise, that means that voltage is still present. Do not proceed with repair until there is no current running.
    Pergunte ao FixBot
    Comentar
  3. Replacing an LED Light Fixture: passo 3, imagem 1 %32 Replacing an LED Light Fixture: passo 3, imagem 2 %32 Replacing an LED Light Fixture: passo 3, imagem 3 %32
    • Locate the breaker to your house/unit and identify the switch which provides power to the light fixture.
    • Flip the switch on the breaker to the right to turn off the power to the light fixture.
    • Go back to the light fixture, and check if it is still receiving power with the voltage detector.
    • The voltage detector should remain green when placed near the electrical line connected to the light fixture.
    Pergunte ao FixBot
    Comentar
  4. Replacing an LED Light Fixture: passo 4, imagem 1 %32 Replacing an LED Light Fixture: passo 4, imagem 2 %32 Replacing an LED Light Fixture: passo 4, imagem 3 %32
    • Begin unscrewing the base of the light fixture from the ceiling.
    Pergunte ao FixBot
    Comentar
  5. Replacing an LED Light Fixture: passo 5, imagem 1 %32 Replacing an LED Light Fixture: passo 5, imagem 2 %32 Replacing an LED Light Fixture: passo 5, imagem 3 %32
    • Once enough screws are removed from the base of the light fixture, hold the center of the base with your free hand so it doesn't fall down on its own.
    Pergunte ao FixBot
    Comentar
  6. Replacing an LED Light Fixture: passo 6, imagem 1 %32 Replacing an LED Light Fixture: passo 6, imagem 2 %32
    • While still holding the base of the light fixture, check if the exposed wires are still unpowered with the voltage detector.
    • The voltage detector should remain green when placed near these exposed wires.
    Pergunte ao FixBot
    Comentar
  7. Replacing an LED Light Fixture: passo 7, imagem 1 %32 Replacing an LED Light Fixture: passo 7, imagem 2 %32
    • Unscrew the screw attached to the metal bracket by twisting the manual Phillips screwdriver until the screw falls off.
    Pergunte ao FixBot
    Comentar
  8. Replacing an LED Light Fixture: passo 8, imagem 1 %32 Replacing an LED Light Fixture: passo 8, imagem 2 %32 Replacing an LED Light Fixture: passo 8, imagem 3 %32
    • Unwrap the electrical tape from around both the black and white wires. These wires will be connected to the base of the light fixture with wire caps (which are yellow in this case).
    • You may want to rest the base of the light fixture on the top of your ladder, or have someone else hold it so that you can use both hands to unwrap the electrical tape.
    Pergunte ao FixBot
    Comentar
  9. Replacing an LED Light Fixture: passo 9, imagem 1 %32 Replacing an LED Light Fixture: passo 9, imagem 2 %32 Replacing an LED Light Fixture: passo 9, imagem 3 %32
    • Remove the wire caps from the black and white wires and place them aside.
    Pergunte ao FixBot
    Comentar
  10. Replacing an LED Light Fixture: passo 10, imagem 1 %32 Replacing an LED Light Fixture: passo 10, imagem 2 %32 Replacing an LED Light Fixture: passo 10, imagem 3 %32
    • Place a piece of electrical tape on the two black wires joined together by the yellow wire connector.
    • Wrap the electrical tape a few times around the wire until both wires are securely wrapped together.
    • Follow the same steps for the white wires.
    Pergunte ao FixBot
    Comentar
  11. Replacing an LED Light Fixture: passo 11, imagem 1 %32 Replacing an LED Light Fixture: passo 11, imagem 2 %32 Replacing an LED Light Fixture: passo 11, imagem 3 %32
    • Screw on the new metal bracket from the replacement light fixture by twisting the manual Phillips screwdriver until the screw is snuggly holding the bracket.
    • This bracket will be placed in the same location that the original bracket was in, so the screw will screw into the same place as the original screw.
    Pergunte ao FixBot
    Comentar
  12. Replacing an LED Light Fixture: passo 12, imagem 1 %32 Replacing an LED Light Fixture: passo 12, imagem 2 %32 Replacing an LED Light Fixture: passo 12, imagem 3 %32
    • Screw on the remaining screws into the metal bracket so that it is firmly attached to the ceiling.
    Pergunte ao FixBot
    Comentar
  13. Replacing an LED Light Fixture: passo 13, imagem 1 %32 Replacing an LED Light Fixture: passo 13, imagem 2 %32 Replacing an LED Light Fixture: passo 13, imagem 3 %32
    • While holding the base of the new light fixture, tuck the black and white wires into the electrical box so that there is very little slack in the wires.
    Pergunte ao FixBot
    Comentar
  14. Replacing an LED Light Fixture: passo 14, imagem 1 %32 Replacing an LED Light Fixture: passo 14, imagem 2 %32
    • Screw the base of the new light fixture into place.
    Pergunte ao FixBot
    Comentar
  15. Replacing an LED Light Fixture: passo 15, imagem 1 %32 Replacing an LED Light Fixture: passo 15, imagem 2 %32 Replacing an LED Light Fixture: passo 15, imagem 3 %32
    • Position the light cover of the new light fixture onto the base.
    • Tighten the thumb screws which hold the light cover so that the cover is tightly secured to to the base.
    Pergunte ao FixBot
    Comentar
  16. Replacing an LED Light Fixture: passo 16, imagem 1 %32 Replacing an LED Light Fixture: passo 16, imagem 2 %32 Replacing an LED Light Fixture: passo 16, imagem 3 %32
    • Flip the switch on the breaker back to the left to turn on the power to the light fixture.
    Pergunte ao FixBot
    Comentar
  17. Replacing an LED Light Fixture: passo 17, imagem 1 %32
    • Test to ensure that the light fixture is working properly.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
UC Davis, Team 1-3, Morris Spring 2024 Membro de UC Davis, Team 1-3, Morris Spring 2024
UCD-MORRIS-S24S1G3
3 Membros
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 50
Últimos 30 dias: 263
Ao todo: 2,740
