Ir para o conteúdo principal
Replacing an Atari Capacitor
O que você precisa
  1. Replacing an Atari Capacitor, Atari Lynx: passo 1, imagem 1 %32
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Replacing an Atari Capacitor: passo 2, imagem 1 %32
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Replacing an Atari Capacitor: passo 3, imagem 1 %32
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Replacing an Atari Capacitor: passo 4, imagem 1 %32
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Replacing an Atari Capacitor, C10 Capacitor: passo 5, imagem 1 %32 Replacing an Atari Capacitor, C10 Capacitor: passo 5, imagem 2 %32
    • Desolder the four aluminum tabs and for more information on soldering click here.
  6. Replacing an Atari Capacitor: passo 6, imagem 1 %32
    • Remove the aluminum back protector to gain access to the C10 capacitor.
  7. Replacing an Atari Capacitor: passo 7, imagem 1 %32 Replacing an Atari Capacitor: passo 7, imagem 2 %32
    • Desolder the C10 capacitor.
Conclusão
Uma outra pessoa concluiu este guia.
John Lopez
Membro desde: 01/27/14
446 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 1-42, Maness Winter 2014 Membro de Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
Membros da 5
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 5,210
