Ir para o conteúdo principal
Replacing Creative Zen X-Fi Button Input Chip Part 1
O que você precisa
  1. Replacing Creative Zen X-Fi Button Input Chip Part 1, Detaching Front Case: passo 1, imagem 1 %32 Replacing Creative Zen X-Fi Button Input Chip Part 1, Detaching Front Case: passo 1, imagem 2 %32 Replacing Creative Zen X-Fi Button Input Chip Part 1, Detaching Front Case: passo 1, imagem 3 %32
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
    Pergunte ao FixBot
    Comentar
  2. Replacing Creative Zen X-Fi Button Input Chip Part 1, Rubber Button Cover: passo 2, imagem 1 %32
    • The black rubber button pad can be removed by simply picking it up.
    Pergunte ao FixBot
    Comentar
  3. Replacing Creative Zen X-Fi Button Input Chip Part 1, Button Input Chip Part 1: passo 3, imagem 1 %32
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
    Pergunte ao FixBot
    Comentar
  4. Replacing Creative Zen X-Fi Button Input Chip Part 1, Button Input Chip: passo 4, imagem 1 %32
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
    Pergunte ao FixBot
    Comentar
Conclusão
Westley Courchene
Membro desde: 01/13/15
3.410 Reputação
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 31
Ao todo: 670
