Ir para o conteúdo principal
Replacing Creative Zen X-Fi Battery
O que você precisa
  1. Replacing Creative Zen X-Fi Battery, Detaching Front Case: passo 1, imagem 1 %32 Replacing Creative Zen X-Fi Battery, Detaching Front Case: passo 1, imagem 2 %32 Replacing Creative Zen X-Fi Battery, Detaching Front Case: passo 1, imagem 3 %32
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
    Pergunte ao FixBot
    Comentar
  2. Replacing Creative Zen X-Fi Battery, Rubber Button Cover: passo 2, imagem 1 %32
    • The black rubber button pad can be removed by simply picking it up.
    Pergunte ao FixBot
    Comentar
  3. Replacing Creative Zen X-Fi Battery, Button Input Chip Part 1: passo 3, imagem 1 %32
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
    Pergunte ao FixBot
    Comentar
  4. Replacing Creative Zen X-Fi Battery, Button Input Chip: passo 4, imagem 1 %32
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
    Pergunte ao FixBot
    Comentar
  5. Replacing Creative Zen X-Fi Battery, Access Midsection Plate: passo 5, imagem 1 %32
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
    Pergunte ao FixBot
    Comentar
  6. Replacing Creative Zen X-Fi Battery, Unscrew below Button Chip: passo 6, imagem 1 %32
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
    Pergunte ao FixBot
    Comentar
  7. Replacing Creative Zen X-Fi Battery, Unscrew below LCD Screen: passo 7, imagem 1 %32
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
    Pergunte ao FixBot
    Comentar
  8. Replacing Creative Zen X-Fi Battery, Separating the Battery: passo 8, imagem 1 %32
    • Use a spudger to pry the battery from the midsection plate.
    • There is adhesive glue underneath the battery, so additional force might be required to separate the battery.
    Pergunte ao FixBot
    Comentar
  9. Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: passo 9, imagem 1 %32 Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: passo 9, imagem 2 %32
    • Locate the soldering joint connecting the battery wires to the power supply, marked by the letters "PS" on the motherboard.
    • Hold the battery wires in place so that access to the soldering joints is not blocked.
    • When using a soldering iron, keep your hands and fingers as far as possible from the iron's tip to avoid burning your skin.
    • Using a soldering iron, melt the solder connecting the red wire to the motherboard. Do the same action to the black wire.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Westley Courchene
Membro desde: 01/13/15
3.410 Reputação
Autoria de 14 guias
2Comentários do guia
very clear pictures!
John - Responder Compartilhar
разбирать нужно со стороны противоположной гнезда наушников!!! поломал так же как и на фото все защелки со стороны кнопок(
Cooper21 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 23
Últimos 30 dias: 88
Ao todo: 8,763
