Ir para o conteúdo principal
Repairing an FJ-3LED Globe Electric Push Light
O que você precisa
  1. Repairing an FJ-3LED Globe Electric Push Light, Repairing an FJ-3LED Globe Electric Push Light: passo 1, imagem 1 %32 Repairing an FJ-3LED Globe Electric Push Light, Repairing an FJ-3LED Globe Electric Push Light: passo 1, imagem 2 %32 Repairing an FJ-3LED Globe Electric Push Light, Repairing an FJ-3LED Globe Electric Push Light: passo 1, imagem 3 %32
    • Lift the black lid off of the battery slot and remove the batteries.
  2. Repairing an FJ-3LED Globe Electric Push Light: passo 2, imagem 1 %32 Repairing an FJ-3LED Globe Electric Push Light: passo 2, imagem 2 %32 Repairing an FJ-3LED Globe Electric Push Light: passo 2, imagem 3 %32
    • Use the Phillips #1 screwdriver to remove four 1.4 mm screws from the back of the light.
    • Take the black part out and separate it from the white case.
  3. Repairing an FJ-3LED Globe Electric Push Light: passo 3, imagem 1 %32
    • Identify which part of the lamp is broken.
    • in this case, one of the connections in the circuit had been disconnected.
  4. Repairing an FJ-3LED Globe Electric Push Light: passo 4, imagem 1 %32
    • For tips on Soldering, see How to Solder and Desolder Connections.
    • Attach the disconnected wire to its joint using solder and iron tip. Place the tip of the soldering iron against the solder pad.
    • Melt enough solder onto the solder pad.
    • Remove both the solder and the soldering iron tip from the connection as soon as enough solder melts onto the pad.
    • Don't forget to use gloves.
  5. Repairing an FJ-3LED Globe Electric Push Light: passo 5, imagem 1 %32 Repairing an FJ-3LED Globe Electric Push Light: passo 5, imagem 2 %32
    • Push the circuit into its place.
    • Click the button to see if the wires are connected .
  6. Repairing an FJ-3LED Globe Electric Push Light: passo 6, imagem 1 %32 Repairing an FJ-3LED Globe Electric Push Light: passo 6, imagem 2 %32
    • If the lights turn on, the connection is perfect in the circuit and the disconnected joint is now connected.
    • Place the white case on top of the circuit and close it with the Phillips #1 screwdriver.
Conclusão
Rojina Saberi
Membro desde: 05/11/21
133 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 264
