Ir para o conteúdo principal
Repairing Minolta Dimage Xt Lens Cover
O que você precisa
    1. Repairing Minolta Dimage Xt Lens Cover, Casing: passo 1, imagem 1 %32 Repairing Minolta Dimage Xt Lens Cover, Casing: passo 1, imagem 2 %32 Repairing Minolta Dimage Xt Lens Cover, Casing: passo 1, imagem 3 %32
      • Locate and remove the silver screws on each side of the camera.
      • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
      Pergunte ao FixBot
      Comentar
    2. Repairing Minolta Dimage Xt Lens Cover: passo 2, imagem 1 %32 Repairing Minolta Dimage Xt Lens Cover: passo 2, imagem 2 %32 Repairing Minolta Dimage Xt Lens Cover: passo 2, imagem 3 %32
      • Then, carefully pry apart the front and back outer casing away from the internal components.
      • Be aware of the ribbon wire that will disconnect when the casing is detached.
      Pergunte ao FixBot
      Comentar
    1. Repairing Minolta Dimage Xt Lens Cover, Lens Cover: passo 3, imagem 1 %32
      • Place the internal electronics face-up. Look at the side with the flash turned towards you.
      • The lens cover is a small sheet of metal that rests directly infront of the lens when the camera is turned off.
      • Check to see if the spring action arm (what the yellow arrow is pointing to) is attached to the lens cover with the small knob in the corner (circled in yellow).
      Pergunte ao FixBot
      Comentar
    2. Repairing Minolta Dimage Xt Lens Cover: passo 4, imagem 1 %32
      Ferramenta utilizada neste passo:
      • If the arm is not attached (as shown in the previous), use tweezers to place the arm over the knob on the lens cover.
      • Inside the yellow circle, the arm is in the correct position.
      Pergunte ao FixBot
      Comentar
Conclusão
Reassemble the casing by reversing steps 1 and 2.
Uma outra pessoa concluiu este guia.
Megan Milam
Membro desde: 03/11/13
56 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 12-4, Benson Spring 2013 Membro de Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 Membros
Autoria de 21 guias
1Comentário do guia
In Bild 3 ist der gelbe Kreis falsch gesetzt: der kleine Knopf ist unten links an der Blende, wie in Bild 4 positioniert. hr
Hubert Rieping - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 43
Ao todo: 1,710
