Ir para o conteúdo principal
Repairing LG 17LX1R LCD Television Power board
O que você precisa
  1. Repairing LG 17LX1R LCD Television Power board, Repairing LG 17LX1R LCD Television Power board: passo 1, imagem 1 %32 Repairing LG 17LX1R LCD Television Power board, Repairing LG 17LX1R LCD Television Power board: passo 1, imagem 2 %32 Repairing LG 17LX1R LCD Television Power board, Repairing LG 17LX1R LCD Television Power board: passo 1, imagem 3 %32
    • This is the LG 17LX1R that will no longer turn on.
    • Remove the cover from the stand by.
    • Press down on the two tabs. The cover should come off easily.
    • Remove the four screws that hold the stand assembly to the chassis.
  2. Repairing LG 17LX1R LCD Television Power board: passo 2, imagem 1 %32 Repairing LG 17LX1R LCD Television Power board: passo 2, imagem 2 %32 Repairing LG 17LX1R LCD Television Power board: passo 2, imagem 3 %32
    • Remove the four Phillips head screws that attach the stand to the chassis.
    • Remove the eight Phillips screws that hold the back to the chassis. Once the screws are removed, the back will simply snap off.
    • Remove the metal shield. It is fastened with six Phillips screws.
  3. Repairing LG 17LX1R LCD Television Power board: passo 3, imagem 1 %32 Repairing LG 17LX1R LCD Television Power board: passo 3, imagem 2 %32 Repairing LG 17LX1R LCD Television Power board: passo 3, imagem 3 %32
    • After the shield is removed, the power board and the main board are visible.
    • Power Board
    • Main Board
    • Fuse
    • Check all capacitors for blown tops and/or leakage.
    • Thoroughly inspect the boards. Brown discoloration around Diode D102 is evidence of a short circuit, possibly a blown component.
    • Disconnect all connectors from the power board
    • Remove the four screws that mount the power board to the chassis.
  4. Repairing LG 17LX1R LCD Television Power board: passo 4, imagem 1 %32 Repairing LG 17LX1R LCD Television Power board: passo 4, imagem 2 %32 Repairing LG 17LX1R LCD Television Power board: passo 4, imagem 3 %32
    • These are the chassis with the power board removed.
    • Discoloration of the back side of the power board is a sign of a faulty diode.
    • Unsolder the diode from the power board.
    • Replacement diode
  5. Repairing LG 17LX1R LCD Television Power board: passo 5, imagem 1 %32 Repairing LG 17LX1R LCD Television Power board: passo 5, imagem 2 %32 Repairing LG 17LX1R LCD Television Power board: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Here is the removed diode. Description on the diode reads LT526 IN4007.
    • Solder the new diode onto the power board. Use a pair of tweezers or hemostat to hold the diode in place while soldering.
    • Once the diode is replaced, clean the board with isopropyl alcohol to get rid of any debris or old flux.
  6. Repairing LG 17LX1R LCD Television Power board: passo 6, imagem 1 %32
    • Device powers on and has audio and video after the repair.
Conclusão
37 outras pessoas executaram este guia.
oldturkey03
Membro desde: 09/29/10
791.325 Reputação
Autoria de 119 guias
Equipe
Global Fixers Membro de Global Fixers
Community
Membros da 35
Autoria de 603 guias
3 comentários
Very nice good job
Bhullana - Responder
good job my frend
youcef - Responder
great idea thats perfect
Joseph Mwangome - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 44
Duração total: 11,126
