Ir para o conteúdo principal
Repairing 1984-1989 Toyota 4Runner Idler Arm
O que você precisa
  1. Repairing 1984-1989 Toyota 4Runner Idler Arm, Repairing 1984-1989 Toyota 4Runner Idler Arm: passo 1, imagem 1 %32
    • First the Idler arm must be removed from the truck. Another guide has instructions to take the arm off.
  2. Repairing 1984-1989 Toyota 4Runner Idler Arm: passo 2, imagem 1 %32 Repairing 1984-1989 Toyota 4Runner Idler Arm: passo 2, imagem 2 %32
    • Place the arm in a vise.
    • Spray the cap with penetrating lubricant.
    • Using a screw driver, tap the idler arm bracket cap off.
    • If it will not come off easily, then check out the trouble shooting page.
  3. Repairing 1984-1989 Toyota 4Runner Idler Arm: passo 3, imagem 1 %32 Repairing 1984-1989 Toyota 4Runner Idler Arm: passo 3, imagem 2 %32 Repairing 1984-1989 Toyota 4Runner Idler Arm: passo 3, imagem 3 %32
    • Using a 19 mm socket, take the nut off from inside the idler arm bracket.
    • If the arm rotates in the bracket, then it can be taken out of the vice and placed on the ground.
    • Once on the ground, your foot can be used to stop the arm from rotating and enable you to put torque on the nut.
    • Once the nut is off, the arm can be gently tapped out of the bracket.
  4. Repairing 1984-1989 Toyota 4Runner Idler Arm: passo 4, imagem 1 %32 Repairing 1984-1989 Toyota 4Runner Idler Arm: passo 4, imagem 2 %32
    • Remove the oil seal.
    • Remove the plastic bushings with a flat head.
    • Both bushings and oil seals should be removed and replaced.
    • Fill the bracket with MP grease and then put the arm back into the bracket.
    • Wipe off any grease that squeezes out of the bracket.
Conclusão
Colton Baker
Membro desde: 10/20/15
328 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 694
