Ir para o conteúdo principal
Esta tradução pode não refletir as atualizações mais recentes do guia de fontes. Ajude a atualizar a tradução ou veja guia de fontes.
Repair electronics
    • Seen from below, the handpiece is oval-shaped. Wrap with a cloth, with a pair of pliers, a nutcracker or similar. start where the feet are and put the oval in a circle. At the same time, press the handpiece upside down, ie with the metal shank in front, onto a wooden base, whereby the inner life is expelled.
    Pergunte ao FixBot
    Comentar
  1. Repair electronics, Remove handpiece base: passo 2, imagem 1 %32
    • Remove the underside of the handpiece by carefully lifting the tabs at the two farthest vertexes of the oval with a small screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Repair electronics, Remove the rubber pad from the motherboard: passo 3, imagem 1 %32
    • Remove the rubber pad from the motherboard
    Pergunte ao FixBot
    Comentar
  3. Repair electronics, Remove plastic cap from metal shaft: passo 4, imagem 1 %32
    • Use a puller to remove the plastic cap from the metal shaft to expose the defective rubber boot.
    Pergunte ao FixBot
    Comentar
    • Thoroughly clean all housing parts with water and cloth.
    • Thoroughly clean the electronics and mechanics with isopropyl alcohol and a fine brush.
    • Also completely rid the metal shaft of any residue.
    Pergunte ao FixBot
    Comentar
  4. Repair electronics, Repair electronics: passo 6, imagem 1 %32
    • Place the inner workings of the handpiece without housing parts in a container in such a way that the main board points downwards and the battery points upwards.
    • Now fill the container with isopropyl alcohol just enough so that the liquid level reaches the circuit board.
    • Leave to stand for 1-2 hours under supervision, then remove the device from the liquid bath and allow to dry.
    Pergunte ao FixBot
    Comentar
  5. Repair electronics, Replace rubber sleeve: passo 7, imagem 1 %32
    • The defective rubber sleeve on the metal shaft must be replaced. A spare part is available for less than € 4 on eBay under the following designation: "Philips electric toothbrush Waterproof sealing parts for HX6730 HX6930 HX9340».
    Pergunte ao FixBot
    Comentar
Conclusão
Repeat the steps in order to reassemble your device.
Uma outra pessoa concluiu este guia.
Um agradecimento especial a esses tradutores:
de en
94%
irlanda está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Gerd Conzetti
Membro desde: 11/12/17
319 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 65
Ao todo: 1,765
