Ir para o conteúdo principal
Removing the Phone Keypad
O que você precisa
  1. Removing the Phone Keypad, Removing the Back Panel: passo 1, imagem 1 %32 Removing the Phone Keypad, Removing the Back Panel: passo 1, imagem 2 %32
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Removing the Phone Keypad: passo 2, imagem 1 %32 Removing the Phone Keypad: passo 2, imagem 2 %32 Removing the Phone Keypad: passo 2, imagem 3 %32
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
    Pergunte ao FixBot
    Comentar
  3. Removing the Phone Keypad, Keypad: passo 3, imagem 1 %32 Removing the Phone Keypad, Keypad: passo 3, imagem 2 %32
    • Locate and unscrew the circled screw using a Philips head #2 screw driver or screw driver head.
    Pergunte ao FixBot
    Comentar
  4. Removing the Phone Keypad: passo 4, imagem 1 %32
    • Lift the motherboard away from the phone housing.
    • Be careful when lifting the motherboard. To prevent damage to the motherboard, gradually lift it from its place in the assembly.
    Pergunte ao FixBot
    Comentar
  5. Removing the Phone Keypad: passo 5, imagem 1 %32 Removing the Phone Keypad: passo 5, imagem 2 %32
    • Now that the motherboard has been lifted out of place, the keypad can be accessed.
    • Using your fingers push the buttons from the the phone toward the lifted motherboard.
    • Remove the keypad from the assembly.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Clemson, Team 15-1, Benson Fall 2012 Membro de Clemson, Team 15-1, Benson Fall 2012
CLEM-BENSON-F12S15G1
4 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 33
Ao todo: 1,409
