Ir para o conteúdo principal
Removing LG VX8350 Screen Assembly
O que você precisa
  1. Removing LG VX8350  Screen Assembly, Battery: passo 1, imagem 1 %32 Removing LG VX8350  Screen Assembly, Battery: passo 1, imagem 2 %32
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
    Pergunte ao FixBot
    Comentar
  2. Removing LG VX8350  Screen Assembly: passo 2, imagem 1 %32 Removing LG VX8350  Screen Assembly: passo 2, imagem 2 %32
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
    Pergunte ao FixBot
    Comentar
  3. Removing LG VX8350  Screen Assembly, Circuit Board Housing: passo 3, imagem 1 %32 Removing LG VX8350  Screen Assembly, Circuit Board Housing: passo 3, imagem 2 %32 Removing LG VX8350  Screen Assembly, Circuit Board Housing: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
    Pergunte ao FixBot
    Comentar
  4. Removing LG VX8350  Screen Assembly: passo 4, imagem 1 %32 Removing LG VX8350  Screen Assembly: passo 4, imagem 2 %32
    • Lift the back cover starting at the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  5. Removing LG VX8350  Screen Assembly: passo 5, imagem 1 %32 Removing LG VX8350  Screen Assembly: passo 5, imagem 2 %32
    • Remove the back cover completely from the phone.
    Pergunte ao FixBot
    Comentar
  6. Removing LG VX8350  Screen Assembly, Circuit Board: passo 6, imagem 1 %32
    • Locate the clamp at bottom right side of the Circuit Board.
    • Pull the circuit board from the phone being cautious to pull out underneath the clamp.
    Pergunte ao FixBot
    Comentar
  7. Removing LG VX8350  Screen Assembly: passo 7, imagem 1 %32 Removing LG VX8350  Screen Assembly: passo 7, imagem 2 %32
    • Locate the ribbon connecting the circuit board to the phone display.
    • Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
    • Remove the circuit board
    Pergunte ao FixBot
    Comentar
  8. Removing LG VX8350  Screen Assembly, Keypad: passo 8, imagem 1 %32 Removing LG VX8350  Screen Assembly, Keypad: passo 8, imagem 2 %32
    • Lift the keyboard and remove it from the phone.
    Pergunte ao FixBot
    Comentar
  9. Removing LG VX8350  Screen Assembly, Screen Cover: passo 9, imagem 1 %32 Removing LG VX8350  Screen Assembly, Screen Cover: passo 9, imagem 2 %32 Removing LG VX8350  Screen Assembly, Screen Cover: passo 9, imagem 3 %32
    • Locate the two rubber circles covering the screws.
    • Remove the rubber covers using tweezers.
    • Using the Phillips head screwdriver, unscrew and remove the two screws.
    Pergunte ao FixBot
    Comentar
  10. Removing LG VX8350  Screen Assembly: passo 10, imagem 1 %32 Removing LG VX8350  Screen Assembly: passo 10, imagem 2 %32 Removing LG VX8350  Screen Assembly: passo 10, imagem 3 %32
    • Close the phone and gently pull outwards from the bottom left portion of the phone cover.
    • Take care not to do this with too much force, as it could crack the cover.
    • Completely remove the cover from the phone.
    Pergunte ao FixBot
    Comentar
  11. Removing LG VX8350  Screen Assembly, Screen Assembly: passo 11, imagem 1 %32 Removing LG VX8350  Screen Assembly, Screen Assembly: passo 11, imagem 2 %32
    • Locate the front music buttons.
    • Remove the music control buttons on the face of the phone.
    Pergunte ao FixBot
    Comentar
  12. Removing LG VX8350  Screen Assembly: passo 12, imagem 1 %32 Removing LG VX8350  Screen Assembly: passo 12, imagem 2 %32
    • While grasping the top and bottom sections torque the pieces until the indicated hinge has popped out. The two sections of the phone are now able to separate.
    • Make sure the right side of the hinge is removed first and not the left as you will likely damage the ribbon connection.
    Pergunte ao FixBot
    Comentar
  13. Removing LG VX8350  Screen Assembly: passo 13, imagem 1 %32 Removing LG VX8350  Screen Assembly: passo 13, imagem 2 %32 Removing LG VX8350  Screen Assembly: passo 13, imagem 3 %32
    • Locate the two speakers. Using a spudger disconnect the speakers from the assembly.
    • Lift the screen assembly from the casing.
    • The screen assembly is completely removed to allow for easier access to the speaker connections when performing further repairs on the speakers.
    Pergunte ao FixBot
    Comentar
Conclusão
James Brandon
Membro desde: 10/18/13
207 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 14-7, Benson Fall 2013 Membro de Clemson, Team 14-7, Benson Fall 2013
CLEM-BENSON-F13S14G7
3 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 31
Ao todo: 1,051
