Ir para o conteúdo principal
Removing HP Compaq dx2000MT Motherboard
O que você precisa
  1. Removing HP Compaq dx2000MT Motherboard, Removing the HP Compaq dx2000MT Case Doors: passo 1, imagem 1 %32
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing HP Compaq dx2000MT Motherboard: passo 2, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 2, imagem 2 %32
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing HP Compaq dx2000MT Motherboard: passo 3, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 3, imagem 2 %32 Removing HP Compaq dx2000MT Motherboard: passo 3, imagem 3 %32
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing HP Compaq dx2000MT Motherboard: passo 4, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 4, imagem 2 %32 Removing HP Compaq dx2000MT Motherboard: passo 4, imagem 3 %32
    • Once again, this may take considerable force.
  5. Removing HP Compaq dx2000MT Motherboard, Optical (CD) Drive: passo 5, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard, Optical (CD) Drive: passo 5, imagem 2 %32 Removing HP Compaq dx2000MT Motherboard, Optical (CD) Drive: passo 5, imagem 3 %32
    • Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
  6. Removing HP Compaq dx2000MT Motherboard: passo 6, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 6, imagem 2 %32
    • Remove the 2 Torx T15 screws holding the optical drive in place.
  7. Removing HP Compaq dx2000MT Motherboard: passo 7, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 7, imagem 2 %32
    • Remove the other 2 Torx T15 screws holding the other side of the drive in place.
  8. Removing HP Compaq dx2000MT Motherboard: passo 8, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 8, imagem 2 %32 Removing HP Compaq dx2000MT Motherboard: passo 8, imagem 3 %32
    • Remove the optical drive by sliding it out the front of the device.
  9. Removing HP Compaq dx2000MT Motherboard, Disassembling HP Compaq dx2000MT Hard Drive: passo 9, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard, Disassembling HP Compaq dx2000MT Hard Drive: passo 9, imagem 2 %32 Removing HP Compaq dx2000MT Motherboard, Disassembling HP Compaq dx2000MT Hard Drive: passo 9, imagem 3 %32
    • Remove the IDE data and power cables from the hard drive.
  10. Removing HP Compaq dx2000MT Motherboard: passo 10, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 10, imagem 2 %32 Removing HP Compaq dx2000MT Motherboard: passo 10, imagem 3 %32
    • Remove the front bezel by pulling upwards and out from below the lowest air vent.
  11. Removing HP Compaq dx2000MT Motherboard: passo 11, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 11, imagem 2 %32 Removing HP Compaq dx2000MT Motherboard: passo 11, imagem 3 %32
    • Remove the external drive faceplate by removing the two Torx T15 screws.
  12. Removing HP Compaq dx2000MT Motherboard: passo 12, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 12, imagem 2 %32
    • Remove the following screws:
    • Front Torx T15.
    • Torx T15 mounting the hard drive cage to the optical drive bay.
  13. Removing HP Compaq dx2000MT Motherboard: passo 13, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 13, imagem 2 %32 Removing HP Compaq dx2000MT Motherboard: passo 13, imagem 3 %32
    • Fully remove the hard drive cage by sliding it towards the back of the device and pulling down.
  14. Removing HP Compaq dx2000MT Motherboard: passo 14, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 14, imagem 2 %32 Removing HP Compaq dx2000MT Motherboard: passo 14, imagem 3 %32
    • Remove the two Torx T15 screws holding this side of the hard drive in place.
  15. Removing HP Compaq dx2000MT Motherboard: passo 15, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 15, imagem 2 %32 Removing HP Compaq dx2000MT Motherboard: passo 15, imagem 3 %32
    • Proceed to the other side of the hard drive cage.
  16. Removing HP Compaq dx2000MT Motherboard: passo 16, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 16, imagem 2 %32
    • Remove the hard drive from the hard drive cage by pulling it outward from the cage.
  17. Removing HP Compaq dx2000MT Motherboard, Case Fan: passo 17, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard, Case Fan: passo 17, imagem 2 %32 Removing HP Compaq dx2000MT Motherboard, Case Fan: passo 17, imagem 3 %32
    • Remove the 3 prong power connector from the motherboard by pulling it outwards toward the side of the device.
  18. Removing HP Compaq dx2000MT Motherboard: passo 18, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 18, imagem 2 %32 Removing HP Compaq dx2000MT Motherboard: passo 18, imagem 3 %32
    • Remove the 4 push fasteners from the case by:
    • Prying them outwards with a small flathead screwdriver and
    • Pulling them out with tweezers or plyers.
  19. Removing HP Compaq dx2000MT Motherboard: passo 19, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 19, imagem 2 %32 Removing HP Compaq dx2000MT Motherboard: passo 19, imagem 3 %32
    • Remove the fan from the case by pulling it towards the front of the device.
  20. Removing HP Compaq dx2000MT Motherboard, PCI Cards: passo 20, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard, PCI Cards: passo 20, imagem 2 %32
    • Remove the Torx T15 screwdriver holding the PCI card in place.
  21. Removing HP Compaq dx2000MT Motherboard: passo 21, imagem 1 %32
    • Remove the PCI card by pulling it out towards the side of the device.
    • Be careful about touching the top and bottom of the card! The static electricity in your fingers could short it. If you can, only touch the metal bracket and the sides of the card.
  22. Removing HP Compaq dx2000MT Motherboard, RAM: passo 22, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard, RAM: passo 22, imagem 2 %32
    • Release the lower portion of the RAM by pushing down on the bottom tab.
  23. Removing HP Compaq dx2000MT Motherboard: passo 23, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 23, imagem 2 %32
    • Release the upper portion of the RAM by pushing down on the upper tab.
  24. Removing HP Compaq dx2000MT Motherboard: passo 24, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 24, imagem 2 %32 Removing HP Compaq dx2000MT Motherboard: passo 24, imagem 3 %32
    • Remove the RAM by pulling it out towards the side of the device
    • Be careful about touching the top (right) and bottom (left)sides of the RAM! The static electricity in your fingers could short it. If you can, only touch the top and bottom of the RAM.
    • If replacing RAM, make sure it is the right type, speed, and size for your computer. Otherwise the RAM may not fit or your computer may not start up.
  25. Removing HP Compaq dx2000MT Motherboard, Power Supply: passo 25, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard, Power Supply: passo 25, imagem 2 %32 Removing HP Compaq dx2000MT Motherboard, Power Supply: passo 25, imagem 3 %32
    • Remove the 4 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device.
  26. Removing HP Compaq dx2000MT Motherboard: passo 26, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 26, imagem 2 %32
    • Remove the 20 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device.
  27. Removing HP Compaq dx2000MT Motherboard: passo 27, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 27, imagem 2 %32 Removing HP Compaq dx2000MT Motherboard: passo 27, imagem 3 %32
    • Remove the 4 Torx T15 screws from the rear of the power supply
  28. Removing HP Compaq dx2000MT Motherboard: passo 28, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 28, imagem 2 %32
    • Slide the power supply towards the front of the device
    • Keep your hand underneath it! You don't want to drop it!
    • Then pull the power supply down and remove it from the case.
  29. Removing HP Compaq dx2000MT Motherboard, Motherboard: passo 29, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard, Motherboard: passo 29, imagem 2 %32 Removing HP Compaq dx2000MT Motherboard, Motherboard: passo 29, imagem 3 %32
    • Remove any IDE cables from the motherboard by pulling them out towards the side of the device.
  30. Removing HP Compaq dx2000MT Motherboard: passo 30, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 30, imagem 2 %32
    • Remove the 2 prong speaker connector by pulling out towards the side of the device.
  31. Removing HP Compaq dx2000MT Motherboard: passo 31, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 31, imagem 2 %32
    • Remove the 16 pin connector from the motherboard by pulling it out towards the side of the device.
  32. Removing HP Compaq dx2000MT Motherboard: passo 32, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 32, imagem 2 %32
    • Remove the 14 pin USB connector by pulling it out towards the side of the device.
  33. Removing HP Compaq dx2000MT Motherboard: passo 33, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 33, imagem 2 %32
    • Remove the 8 Torx T15 screws from the motherboard.
  34. Removing HP Compaq dx2000MT Motherboard: passo 34, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 34, imagem 2 %32
    • Remove the 3 pin power connector by pulling it out towards the side of the device.
  35. Removing HP Compaq dx2000MT Motherboard: passo 35, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 35, imagem 2 %32
    • Unscrew the 4 Torx T15 screws holding the CPU Cooler in place.
    • Make sure to hold your cpu cooler when removing the screws. You don't want it to fall!
  36. Removing HP Compaq dx2000MT Motherboard: passo 36, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 36, imagem 2 %32
    • Remove the cpu cooler by pulling out towards the side of the device.
    • Make sure you do not touch where the cpu cooler makes contact with the processor! You do not want to contaminate the thermal paste that separates these components.
    • When replacing your cpu cooler, make sure you clean the processor contact area on the cooler and processor with isopropyl rubbing alcohol.
    • We have a guide for reapplying thermal paste that makes this easy.
  37. Removing HP Compaq dx2000MT Motherboard: passo 37, imagem 1 %32 Removing HP Compaq dx2000MT Motherboard: passo 37, imagem 2 %32
    • Remove the motherboard by pushing it forwards and removing it from the case.
Conclusão
18 outras pessoas executaram este guia.
Logan Pace
Membro desde: 10/12/11
2.224 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 17-16, Regan Fall 2011 Membro de Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
Membros da 4
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 23
Duração total: 10,371
