Ir para o conteúdo principal
Remove the Write Protect Screw
O que você precisa
  1. Remove the Write Protect Screw, Remove the rubber pads: passo 1, imagem 1 %32 Remove the Write Protect Screw, Remove the rubber pads: passo 1, imagem 2 %32
    • Flip your Chromebook Pixel over onto its back
    • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
    Pergunte ao FixBot
    Comentar
  2. Remove the Write Protect Screw, Removing the bottom panel: passo 2, imagem 1 %32 Remove the Write Protect Screw, Removing the bottom panel: passo 2, imagem 2 %32 Remove the Write Protect Screw, Removing the bottom panel: passo 2, imagem 3 %32
    • Using a small Philips screwdriver, remove the four screws under the pads
    • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
    • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
    Pergunte ao FixBot
    Comentar
  3. Remove the Write Protect Screw, Pop it open: passo 3, imagem 1 %32 Remove the Write Protect Screw, Pop it open: passo 3, imagem 2 %32
    • Gently pull up from the front of the laptop and open it up like a clamshell
    Pergunte ao FixBot
    Comentar
  4. Remove the Write Protect Screw, Remove the write protect screw (IF APPLICABLE): passo 4, imagem 1 %32 Remove the Write Protect Screw, Remove the write protect screw (IF APPLICABLE): passo 4, imagem 2 %32
    • Locate the write protect screw
    • Remove it and you can begin flashing your BIOS!
    Pergunte ao FixBot
    Comentar
Conclusão
16 outras pessoas executaram este guia.
Kevin Fessler
Membro desde: 04/16/16
1.857 Reputação
Autoria de 4 guias
4Comentários do guia
removing this will allow me to boot and install windows?
john Akday - Responder Compartilhar
It will allow you to install Windows to the main hard drive and boot to it, but! As of yet, there’s no way that I’ve found to get the trackpad working in Windows with the Chromebook Pixel.
Kevin Purdy - Responder Compartilhar
You will find more information here:
https://coolstar.org/chromebook/windows-...
Lino Bolivar - Responder Compartilhar
Acer R752TN write protect screw location?
Fredrik Løvås - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 41
Últimos 30 dias: 217
Ao todo: 46,026
