Ir para o conteúdo principal
Remove RAM
O que você precisa
Documento em destaque
Pré-visualização da primeira página deste documento
Lenovo Legion 9 16irx9 Hmm
Faça login para ver o documento completo
Login
    1. Remove RAM, Remove screws from bottom of laptop.: passo 1, imagem 1 %32 Remove RAM, Remove screws from bottom of laptop.: passo 1, imagem 2 %32
      • Flip the computer over to access the screws on the bottom.
      • Remove 8 black, 7mm PH0 screws (M2 x L7).
      • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
      Pergunte ao FixBot
      Comentar
      • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
      Pergunte ao FixBot
      Comentar
    1. Remove RAM, Disconnect battery cable: passo 3, imagem 1 %32
      • Almost anything that is done with a computer is safer if the battery is disconnected, so it is good to do that now.
      • Disconnect the battery pack cable from the system board using fingernails or a pry bar. Use your fingernails to pull the connector to unplug it. Do not pull the cable. It can be very tight. I used a 3.5 mm flathead screwdriver to carefully push the side plastic edges down towards the battery. Do not knock any of the components on the board.
      Pergunte ao FixBot
      Comentar
    1. Remove RAM, Remove battery screws: passo 4, imagem 1 %32
      • Remove 6 black 4mm PH1 screws (M2 x L4). The lower right screw is close to a magnet that may pull it from where you want it to go - tweezers may be necessary. The Hardware Maintenance Manual does not show the bottom middle screw.
      • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
      Pergunte ao FixBot
      Comentar
      • Lift out the battery.
      Pergunte ao FixBot
      Comentar
    1. Remove RAM, Remove the system board mylar: passo 6, imagem 1 %32 Remove RAM, Remove the system board mylar: passo 6, imagem 2 %32
      • Remove the system board mylar.
      • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
      Pergunte ao FixBot
      Comentar
    1. Remove RAM, Remove the solid-state drive (SSD) shielding: passo 7, imagem 1 %32
      • Remove 4 black PH1 screws (M2 x L4) and then remove the SSD shielding.
      Pergunte ao FixBot
      Comentar
    1. Remove RAM, Unscrew Solid-State Drives (SSD): passo 8, imagem 1 %32
      • Remove 2 silver 2mm PH1 screws (M2 x L2), one for each SSD.
      Pergunte ao FixBot
      Comentar
      • Remove each SSD by pulling it away from the slot.
      • Note: it may be important to replace the SSDs into the same slot, so label them in some manner - perhaps "T" for the top one and "B" for the bottom one.
      Pergunte ao FixBot
      Comentar
    1. Remove RAM, Remove the Wi-Fi card: passo 10, imagem 1 %32
      • Detach the main and auxiliary antenna cable connectors. Note which colour cable is connected to each post - the photographed board has a grey cable connected to the top post (marked as "#1 Aux" with a white triangle on the Wi-Fi card) and a black cable connected to the bottom post (marked as "#2 Main" with a black triangle on the Wi-Fi card).
      • Remove 1 silver 2mm PH1 screw (M2 x L2).
      • Remove the Wi-Fi card by pulling it away from the slot.
      Pergunte ao FixBot
      Comentar
    1. Remove RAM, Disconnect tape and cables: passo 11, imagem 1 %32
      • (1) Peel off the thermal DIMM plate tape from the system board.
      • (2-3) Lift flap and disconnect the I/O board cable from the system board.
      • (2-3) Lift flap and disconnect the audio FPC cable from the system board.
      • (2-3) Lift flap and disconnect the hinge cap lightingbar cable from the system board.
      • Note: my machine did not have the DIMM plate tape or the cable in the upper right.
      Pergunte ao FixBot
      Comentar
    2. Remove RAM, Disconnect the fan cables: passo 12, imagem 1 %32
      • Disconnect the three fan cables from the system board by lifting away from board.
      Pergunte ao FixBot
      Comentar
    3. Remove RAM, Remove screws and fans: passo 13, imagem 1 %32
      • Remove 7 black 6mm PH1 screws (M2 x L6) holding the fans.
      • Remove tape from fans - possibly using gentle heat
      • Remove the fans - be careful of Wi-Fi antenna cables around top left fan and speaker cable around small bottom right fan.
      Pergunte ao FixBot
      Comentar
    1. Remove RAM, Disconnect cables: passo 14, imagem 1 %32
      • Disconnect 9 cables connected to the system board.
      Pergunte ao FixBot
      Comentar
    2. Remove RAM, Disconnect more cables: passo 15, imagem 1 %32
      • Disconnect five more cables from the system board
      Pergunte ao FixBot
      Comentar
      • Remove 3 black 4mm PH1 screws (M2 x L4) screws
      • Remove 2 black 6mm PH1 screws (M2 x L4) screws
      • Remove the flaps of tape holding the antenna wires to the board.
      • Remove the system board module carefully.
      Pergunte ao FixBot
      Comentar
      • Position the board over so that the heat sink tubes are on the top
      • Remove the sheet over the RAM modules.
      • Release the latches on both edges of the each socket at the same time to remove each memory module.
      Pergunte ao FixBot
      Comentar
Conclusão
Documentos anexados
johann beda
Membro desde: 09/13/10
3.428 Reputação
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 22
Ao todo: 111
