Ir para o conteúdo principal
Remington MB4040 Thermal Switch Replacement
O que você precisa
  1. Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: passo 1, imagem 1 %32 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: passo 1, imagem 2 %32 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: passo 1, imagem 3 %32
    • Press the black button below the blade to remove the blade.
  2. Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: passo 2, imagem 1 %32 Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: passo 2, imagem 2 %32
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: passo 3, imagem 1 %32 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: passo 3, imagem 2 %32 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: passo 3, imagem 3 %32
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  4. Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): passo 4, imagem 1 %32 Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): passo 4, imagem 2 %32
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  5. Remington MB4040 Thermal Switch Replacement, Blade Button Removal: passo 5, imagem 1 %32 Remington MB4040 Thermal Switch Replacement, Blade Button Removal: passo 5, imagem 2 %32
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
  6. Remington MB4040 Thermal Switch Replacement, Remove Motherboard: passo 6, imagem 1 %32 Remington MB4040 Thermal Switch Replacement, Remove Motherboard: passo 6, imagem 2 %32
  7. Remington MB4040 Thermal Switch Replacement, Remove Thermal Switch: passo 7, imagem 1 %32
    • Separate the thermal switch from the battery by using a spudger to pry it from the adhesive.
    • Use a low temperature RTV to readhere the thermal switch to the battery.
    • Remove the soldering holding the thermal switch to the motherboard.
Conclusão
3 outras pessoas executaram este guia.
Cameron Carnahan
Membro desde: 01/20/15
1.082 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 1-5, Blackwell Winter 2015 Membro de USF Tampa, Team 1-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G5
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 14
Duração total: 3,019
