Ir para o conteúdo principal
Refrigerator Handle with No Drills Installation
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Refrigerator Handle with No Drills Installation, Refrigerator Handle with No Drills Installation: passo 1, imagem 1 %32 Refrigerator Handle with No Drills Installation, Refrigerator Handle with No Drills Installation: passo 1, imagem 2 %32 Refrigerator Handle with No Drills Installation, Refrigerator Handle with No Drills Installation: passo 1, imagem 3 %32
    • Use a clean sponge or damp lint free cloth to apply the handle to the surface.
    • Soapy water or other mild cleansers may be used to clean the surface from all grease or grime.
    • Preferably use cold or luke warm water.
  2. Refrigerator Handle with No Drills Installation: passo 2, imagem 1 %32 Refrigerator Handle with No Drills Installation: passo 2, imagem 2 %32 Refrigerator Handle with No Drills Installation: passo 2, imagem 3 %32
    • Gently clean the surface of refrigerator where handle will be applied.
    • Ensure the surface is completely dry before application.
  3. Refrigerator Handle with No Drills Installation: passo 3, imagem 1 %32 Refrigerator Handle with No Drills Installation: passo 3, imagem 2 %32 Refrigerator Handle with No Drills Installation: passo 3, imagem 3 %32
    • Clean the bottom of the handle's suction cups with a damp sponge or lint-free towel.
    • Ensure the surface is completely dry up before application.
  4. Refrigerator Handle with No Drills Installation: passo 4, imagem 1 %32
    • Once both surfaces are dry, place the handle with suction cups facing the refrigerator.
    • Position the handle on the side you would open the refrigerator.
  5. Refrigerator Handle with No Drills Installation: passo 5, imagem 1 %32
    • Position the handle vertically and at an appropriate height.
    • The height is up to your own personal preference.
  6. Refrigerator Handle with No Drills Installation: passo 6, imagem 1 %32 Refrigerator Handle with No Drills Installation: passo 6, imagem 2 %32
    • Apply pressure to both ends of the handle for approximately 15 seconds.
  7. Refrigerator Handle with No Drills Installation: passo 7, imagem 1 %32 Refrigerator Handle with No Drills Installation: passo 7, imagem 2 %32 Refrigerator Handle with No Drills Installation: passo 7, imagem 3 %32
    • Lock the suction cups in place by pushing down on the hatches.
    • Depending on manufacturer, locking the suction handles may differ in method.
  8. Refrigerator Handle with No Drills Installation: passo 8, imagem 1 %32 Refrigerator Handle with No Drills Installation: passo 8, imagem 2 %32
    • Slowly release the handle.
    • If handle detaches, repeat steps 4-8 until successful.
Conclusão
Jaskaran Buttar
Membro desde: 09/29/15
125 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-7, Green Fall 2015 Membro de Cal Poly, Team 10-7, Green Fall 2015
CPSU-GREEN-F15S10G7
Membros da 3
Autoria de 3 guias
Um comentário
Help to fix a big hole where the door is holding on door falling off
Joya Hall - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 273
