Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The RJ-14 connector is designed to connect to pedals that do not come with the device. This guide will show you how to replace the RJ-14 connector located at the bottom of the guitar.
O que você precisa
Remove the strap by pulling it off of the mounts located on the body and neck.
Remove the two 10mm Phillips #1 screws from the RJ-14 connector board.
Lift the RJ-14 connector to remove it from the case.
