Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the strap by pulling it off of the mounts located on the body and neck.
Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
Pull off the rear case.
Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
Pull off the top shell of the neck to expose the internal features.
Remove the two 10mm Phillips #1 screws from the RJ-14 connector board.
Lift the RJ-14 connector to remove it from the case.
