Ir para o conteúdo principal
RedOctane X-Plorer Keys Replacement
O que você precisa
  1. RedOctane X-Plorer Keys Replacement, Rear Case: passo 1, imagem 1 %32 RedOctane X-Plorer Keys Replacement, Rear Case: passo 1, imagem 2 %32
    • Remove the strap by pulling it off of the mounts located on the body and neck.
    Pergunte ao FixBot
    Comentar
  2. RedOctane X-Plorer Keys Replacement: passo 2, imagem 1 %32 RedOctane X-Plorer Keys Replacement: passo 2, imagem 2 %32 RedOctane X-Plorer Keys Replacement: passo 2, imagem 3 %32
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
    Pergunte ao FixBot
    Comentar
  3. RedOctane X-Plorer Keys Replacement: passo 3, imagem 1 %32 RedOctane X-Plorer Keys Replacement: passo 3, imagem 2 %32 RedOctane X-Plorer Keys Replacement: passo 3, imagem 3 %32
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
    Pergunte ao FixBot
    Comentar
  4. RedOctane X-Plorer Keys Replacement, Keys: passo 4, imagem 1 %32 RedOctane X-Plorer Keys Replacement, Keys: passo 4, imagem 2 %32 RedOctane X-Plorer Keys Replacement, Keys: passo 4, imagem 3 %32
    • Use a screwdriver to remove the 10 mm Phillips #1 screws from the key sensor board.
    • Lift up on the key sensor board to remove it from the guitar neck.
    • When using the screwdriver, make sure to avoid puncturing the wires.
    Pergunte ao FixBot
    Comentar
  5. RedOctane X-Plorer Keys Replacement: passo 5, imagem 1 %32
    • Using your fingers, remove the rubber pad to expose the colored keys.
    Pergunte ao FixBot
    Comentar
  6. RedOctane X-Plorer Keys Replacement: passo 6, imagem 1 %32 RedOctane X-Plorer Keys Replacement: passo 6, imagem 2 %32
    • Reach one finger under the guitar to push the key out of the casing.
    • Repeat this step for the four remaining keys.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Ashley Slocum
Membro desde: 04/18/18
228 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S17-G1, Livingston Spring 2018 Membro de Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Membros
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 41
Ao todo: 4,858
