Ir para o conteúdo principal
Reconnecting Screen to Logic Board Guide
O que você precisa
  1. Reconnecting Screen to Logic Board Guide, Screen: passo 1, imagem 1 %32
    • Flip the device over
    Pergunte ao FixBot
    Comentar
  2. Reconnecting Screen to Logic Board Guide: passo 2, imagem 1 %32
    • Unscrew the 2 screws closest to the screen
    Pergunte ao FixBot
    Comentar
  3. Reconnecting Screen to Logic Board Guide: passo 3, imagem 1 %32
    • Flip the device back over
    • It is now standing right side up
    Pergunte ao FixBot
    Comentar
  4. Reconnecting Screen to Logic Board Guide: passo 4, imagem 1 %32
    • Unscrew the top.
    Pergunte ao FixBot
    Comentar
  5. Reconnecting Screen to Logic Board Guide: passo 5, imagem 1 %32
    • Take the top of the device off.
    Pergunte ao FixBot
    Comentar
  6. Reconnecting Screen to Logic Board Guide: passo 6, imagem 1 %32
    • Unscrew the button board.
    Pergunte ao FixBot
    Comentar
  7. Reconnecting Screen to Logic Board Guide: passo 7, imagem 1 %32
    • Take off the button board.
    Pergunte ao FixBot
    Comentar
  8. Reconnecting Screen to Logic Board Guide: passo 8, imagem 1 %32
    • Unscrew all visible screws on the black logic board cover.
    Pergunte ao FixBot
    Comentar
  9. Reconnecting Screen to Logic Board Guide: passo 9, imagem 1 %32
    • Lift the screen straight up out of the device.
    Pergunte ao FixBot
    Comentar
  10. Reconnecting Screen to Logic Board Guide: passo 10, imagem 1 %32
    • Check that the single input plug from the logic board to the screen (reverse side) is completely pushed in by pressing it firmly into the socket.
    • Also check that the 2 output plugs from the screen to the logic board are completely pushed in by pressing them firmly into the highlighted sockets.
    • You have successfully reconnected your display screen.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Nick Sherman
Membro desde: 09/26/12
31 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 7-50, Forte Fall 2012 Membro de Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 28
Ao todo: 898
