Ir para o conteúdo principal
Razer Wolverine V3 Pro Battery Replacement
O que você precisa
  1. Razer Wolverine V3 Pro Battery Replacement, Outer Shell: passo 1, imagem 1 %32 Razer Wolverine V3 Pro Battery Replacement, Outer Shell: passo 1, imagem 2 %32 Razer Wolverine V3 Pro Battery Replacement, Outer Shell: passo 1, imagem 3 %32
    • Insert the end of a spudger or opening tool in the seam at the top of the controller.
    • Slide it around the edge to release the retaining clips.
    • Use the spudger to separate the front and back plastic outer shell of the controller.
    • Both panels should separate from the front of the bumpers.
    • This takes some patience to ensure the panels don’t crack.
    • Flip the controller so the bottom is facing up.
    • Use the spudger to separate the plastic covering on the hand grips.
    Pergunte ao FixBot
    Comentar
  2. Razer Wolverine V3 Pro Battery Replacement: passo 2, imagem 1 %32 Razer Wolverine V3 Pro Battery Replacement: passo 2, imagem 2 %32
    • Use a JIS #0 screwdriver to remove ten 10 mm screws from the mid-frame.
    • Keep screws organized.
    Pergunte ao FixBot
    Comentar
  3. Razer Wolverine V3 Pro Battery Replacement: passo 3, imagem 1 %32 Razer Wolverine V3 Pro Battery Replacement: passo 3, imagem 2 %32
    • Use your hands to pry the back panel of the controller.
    • You now have access to the back buttons (2 on each side).
    Pergunte ao FixBot
    Comentar
  4. Razer Wolverine V3 Pro Battery Replacement: passo 4, imagem 1 %32 Razer Wolverine V3 Pro Battery Replacement: passo 4, imagem 2 %32
    • Remove the two JIS #0 scews securing the battery.
    Pergunte ao FixBot
    Comentar
  5. Razer Wolverine V3 Pro Battery Replacement: passo 5, imagem 1 %32 Razer Wolverine V3 Pro Battery Replacement: passo 5, imagem 2 %32
    • Lift the actuators out of the way to access the screws beneath.
    • Use a Phillips #0 screwdriver to remove the two 6.9 mm screws under the voice coil actuators.
    Pergunte ao FixBot
    Comentar
  6. Razer Wolverine V3 Pro Battery Replacement: passo 6, imagem 1 %32
    • Remove the face cover from the controller.
    • The buttons may fall out in the process of removing the face cover. Be careful to not to lose them.
    • Now you have access to the internal components of the controller.
    Pergunte ao FixBot
    Comentar
  7. Razer Wolverine V3 Pro Battery Replacement, Battery: passo 7, imagem 1 %32 Razer Wolverine V3 Pro Battery Replacement, Battery: passo 7, imagem 2 %32
    • The battery is the black rectangle shown in this figure.
    • Use a JIS #0 screwdriver to remove six screws.
    • One at each corner [6 mm].
    • One in the middle of the battery [3mm].
    • One right above the battery [4 mm].
    Pergunte ao FixBot
    Comentar
  8. Razer Wolverine V3 Pro Battery Replacement: passo 8, imagem 1 %32 Razer Wolverine V3 Pro Battery Replacement: passo 8, imagem 2 %32 Razer Wolverine V3 Pro Battery Replacement: passo 8, imagem 3 %32
    • Use the spudger to gently disconnect the small circuit board on top of the battery cover.
    • Use the angled tweezers to pull the white JST connectors out of their sockets.
    Pergunte ao FixBot
    Comentar
  9. Razer Wolverine V3 Pro Battery Replacement: passo 9, imagem 1 %32 Razer Wolverine V3 Pro Battery Replacement: passo 9, imagem 2 %32 Razer Wolverine V3 Pro Battery Replacement: passo 9, imagem 3 %32
    • Remove the battery from the controller.
    • The battery is glued to the black cover.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 11
Últimos 30 dias: 74
Ao todo: 131
