Ir para o conteúdo principal
Razer Wolverine V3 Pro Action Buttons Replacement
O que você precisa
  1. Razer Wolverine V3 Pro Action Buttons Replacement, Outer Shell: passo 1, imagem 1 %32 Razer Wolverine V3 Pro Action Buttons Replacement, Outer Shell: passo 1, imagem 2 %32 Razer Wolverine V3 Pro Action Buttons Replacement, Outer Shell: passo 1, imagem 3 %32
    • Insert the end of a spudger or opening tool in the seam at the top of the controller.
    • Slide it around the edge to release the retaining clips.
    • Use the spudger to separate the front and back plastic outer shell of the controller.
    • Both panels should separate from the front of the bumpers.
    • This takes some patience to ensure the panels don’t crack.
    • Flip the controller so the bottom is facing up.
    • Use the spudger to separate the plastic covering on the hand grips.
    Pergunte ao FixBot
    Comentar
  2. Razer Wolverine V3 Pro Action Buttons Replacement: passo 2, imagem 1 %32 Razer Wolverine V3 Pro Action Buttons Replacement: passo 2, imagem 2 %32
    • Use a JIS #0 screwdriver to remove ten 10 mm screws from the mid-frame.
    • Keep screws organized.
    Pergunte ao FixBot
    Comentar
  3. Razer Wolverine V3 Pro Action Buttons Replacement: passo 3, imagem 1 %32 Razer Wolverine V3 Pro Action Buttons Replacement: passo 3, imagem 2 %32
    • Use your hands to pry the back panel of the controller.
    • You now have access to the back buttons (2 on each side).
    Pergunte ao FixBot
    Comentar
  4. Razer Wolverine V3 Pro Action Buttons Replacement: passo 4, imagem 1 %32 Razer Wolverine V3 Pro Action Buttons Replacement: passo 4, imagem 2 %32
    • Remove the two JIS #0 scews securing the battery.
    Pergunte ao FixBot
    Comentar
  5. Razer Wolverine V3 Pro Action Buttons Replacement: passo 5, imagem 1 %32 Razer Wolverine V3 Pro Action Buttons Replacement: passo 5, imagem 2 %32
    • Lift the actuators out of the way to access the screws beneath.
    • Use a Phillips #0 screwdriver to remove the two 6.9 mm screws under the voice coil actuators.
    Pergunte ao FixBot
    Comentar
  6. Razer Wolverine V3 Pro Action Buttons Replacement: passo 6, imagem 1 %32
    • Remove the face cover from the controller.
    • The buttons may fall out in the process of removing the face cover. Be careful to not to lose them.
    • Now you have access to the internal components of the controller.
    Pergunte ao FixBot
    Comentar
  7. Razer Wolverine V3 Pro Action Buttons Replacement, Action Buttons: passo 7, imagem 1 %32
    • Flip the front of the outer shell toward you. The old buttons should fall out, but if they remain in place, push them out.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 37
Últimos 30 dias: 112
Ao todo: 162
