Introdução
If your Razer Naga Epic Chroma Mouse doesn’t respond properly or continues to turn on and off at random times, it’s likely due to a faulty battery.
Prior to this guide make sure to check the troubleshooting guide as other problems are caused by these issues as well. Be sure to check all the Razer Naga Epic Chroma Guides for more information related to troubleshooting your mouse.
A punctured battery can cause a dangerous fire. If your battery is swollen, take appropriate precautions.
O que você precisa
Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
Take your nylon spudger to gently pry the battery pack from the device.
Remove the foam on the battery shell for your new battery.
7 outras pessoas executaram este guia.
13 comentários
You can purchase the battery from Amazon. I used the recommendation from ak48disk below, switching the battery leads: https://www.amazon.com/gp/product/B0767K...
Anyone know where to buy a new battery?
that battery appears to be very swollen………
